Turn signal flashed relay location
Discussion in 'Peterbilt Forum' started by Z800xp, Sep 12, 2019.
  1. Z800xp
    Z800xp Bobtail Member
    20
    Feb 26, 2019
    I have a 2019 367 and can't figure out where the relay is exactly located. Need to do a led flashed conversion.
  3. QUALITYTRUCK
    1,801
    1,762
    Jun 14, 2009
    romulus,mi
    Just use 2 of these. Check EBay.
    10x 50W 6 ohm Load Resistor Fix LED Bulb Fast Hyper Flash Turn Signal Blink
    pushbroom Thanks this.
  4. pushbroom
    pushbroom Road Train Member
    1,777
    7,253
    Sep 1, 2012
    There is no flasher relay. All is done in the cecu/chassis node. The cecu can be programmed for led lights though.
    spsauerland Thanks this.
  5. Z800xp
    20
    Feb 26, 2019
    What is the cecu? I guess that means a dealer has to reprogram it and it is not related to the engine which I could take to my nearest Cummins dealer?
  6. QUALITYTRUCK
    1,801
    1,762
    Jun 14, 2009
    romulus,mi
    The program is called ESA. Cummins does not have it. Kenworth/Pete/Some of us have it.
