Turbos going out in cat c15
Discussion in 'Trucks [ Eighteen Wheelers ]' started by lokahi117, Jul 1, 2014.
  1. lokahi117
    lokahi117 Light Load Member
    86
    7
    Oct 7, 2012
    So my co driver just told me that our Pete 379 2007 with a cat c15 acert double turbo is squeezing badly at 1500 RPms or more and shakes badly. I'm thinking it's turbo related.
    How could I diagnose the turbos or rule them out? And if it is the turbos how much are the parts to replace them and how hard is it to do?
    Do I need any specialty tools or anything?
    Whats the best option for turbo replacements for this motor?
    THanks guys for helping us out. As it stands we are currently stuck. Thanks again
  3. maggard359
    maggard359 Medium Load Member
    476
    413
    Nov 20, 2013
    Florida
    Only way to check is to pull intake and exhaust and visually check for damage and play. The acerts are bad for an exhaust sleeve coming apart and taking both turbos out. They are also bad for broken actuator/rocker bolts. Squeeling could be a bad air leak in intake piping or charge air cooler as well as turbos. A bad leak can cause the symptoms you are describing. I would check that first. It's a royal pain to remove all the piping to check the turbos.
    TheBaron97 and lokahi117 Thank this.
  4. lokahi117
    86
    7
    Oct 7, 2012
    Can it use aftermarket turbos? And if so which ones? And how much are the turbos themselves if I have to buy new cat ones vs aftermarket ones?
    It's odd though because we are not having any issues out of the normal when we are unloaded and weighing in at 50,000 so it appears to only be having while loaded and under heAvy load. Any ideas?
  5. Cat sdp
    Cat sdp . .
    20,954
    72,931
    Apr 8, 2012
    Orion's Belt
    I believe there are no upgrades for the "twins"......
  6. maggard359
    476
    413
    Nov 20, 2013
    Florida
    3000-4000 for the set from cat. I am unsure on aftermarket. Plan on broken mounting bolts and new sleeves when you change them. No special tools needed just lots of patience. Need to do a pressure test on intake system first. If creative you can do test with plastic tubs, clamps, and a gauge with air port. Load 30psi and spray with soapy water. Squeeling turbos you should have an easy leak to find. Unless you are loaded the twins can keep up boost, but under load sounds like you are losing boost. They will scream like a raped ape when a boot is blown or a blown manifold. You may have bad turbo(s), but I would check air system first, it will only cost you time. Good luck.
    TheBaron97, lokahi117 and 04 LowMax Thank this.
  7. lokahi117
    86
    7
    Oct 7, 2012
    Hmmmm, so pressure testing the system to thirty psi will reveal any leaks, which would be helpful.
    I am in the truck now, and it seems to not have the turbo squeal . So I, thinking co driver didn't really know what was going on. He didn't know what his boost pressure or turbo temp was at the time, so I'm thinking maybe he overheated the turbos.....but I'm not sure.
    I do notice it shakes and has less power under load.....so I'll start up another thread for that.
  8. 3794life
    3794life Bobtail Member
    6
    Dec 5, 2014
    i purchased after market high pressure turbo here in cali about a year ago at a cost of 950$ put it on my self and im very satistfy. you just need basic mechanic hands, and some basic tools.
    but what you do need is to be a round any one of them dealers who serving cat engine incase you you`ll new v clamps.
  9. 4x4_Welder
    4x4_Welder Medium Load Member
    300
    213
    Sep 16, 2014
    Eastern Orygun
    When pricing out parts, try pricing through your Peterbilt dealer. I have frequently gotten Cat parts much cheaper from them than as a walk-in at Cat.
  10. Lucar
    Lucar Road Train Member
    1,396
    891
    Aug 22, 2012
    Texas
    Run an oil test also, see what you find
  11. Helowrenchturn2
    Helowrenchturn2 Medium Load Member
    484
    140
    Apr 23, 2013
