Any of you fellas tried one of these fancy mechanical VGT’s from DPS in Salt Lake City? Been out for pickups for a few years now and had good results, but I can’t find much for us big displacement owners
Turbonator reviews?
Discussion in 'Ask An Owner Operator' started by Short Pull, Mar 23, 2022.
A friend of mine had a switchblade on a 3406B I’ll let him give his opinion as he ran it a pretty good while @Oxbow.
I tried the switchblade........made it 8 miles and turned around to take it back off. Saw turbo inlet temps well over 1400 degrees with a light load at 1500’ elevation. I couldn’t imagine what the pyrometer would say running through the mountains with a decent load on! This other turbo is similar to Holset VGT’s, but designed to handle soot from our older engines. Variable exhaust housing from 0.7 A/R all the way up to 1.7 A/R to really let the engine breath......in theory
JoeyJunk Thanks this. -
Well you already tried it, but my experience was that it wasn't nearly as good as a 177148 for spool up, but did breathe a touch better at higher RPM. I didn't have the exhaust temp problems like you and we pull up to 138k at higher elevations, mostly 4500 ft to over 8000. They did have some problems with the gate sticking I guess. It supposed to start opening at 8psi. I wonder if that was happening to you? The one the one I had was a 78mm compressor and I'm not sure what the exhaust housing was.
I had a valve come apart and it dinged up the turbine a bit. @wore out turned me on to a much better set up that I have on now.spsauerland, cke, Last Call and 1 other person Thank this. -
He didn’t want to send me a 78 mm, said the 75 mm was plenty big. I pulled a 78 mm off to try his and it wasn’t worth it. He’s arguing with me now that there’s something wrong with my engine.......but funny enough it runs just fine with my old turbo back on again. Just didn’t feel like the engine could breathe with that other conglomeration hanging on the manifold
Any idea what you’re making for hp out of the B model?
Oxbow Thanks this. -
I had a cartridge put in the switchblade that @Oxbow sent me. And just because I hadda know I stuck it on to try it out. Lost some spool up and boost pressure itself which doesn’t bother me most times as some set ups will do more on less boost. It would heat to 900 pretty quick and lost a lot of upper rpm power. To be fair I run a anything but stock B model and run an 80mm in a 1.45 housing on mine. So I am not comparing apples to apples here.
I honestly cannot see the other one being much better.spsauerland, cke and Oxbow Thank this. -
spsauerland and cke Thank this.
I used to have a 1994 379 Pete with a C model in it. Wasn’t a PEEC engine, just a good ol’ mechanical. Ran right with most of the new 550 E Models of the day. With the right parts and a good pump guy they’ll run real good!! Ran a lot of critters across the country with that engine! Are you guys still running the big mechanical exhaust manifold?
I had the same thing with that switchblade on my truck. Lost nearly 10 psi of boost compared to the 78mm that was on it. If it was a bigger frame charger I’d be ok with that as long as it was moving the volume of air needed, but those high egt’s tell me that wasn’t happening either
