turbo wing a help or just an ornament
Discussion in 'Ask An Owner Operator' started by captw900, Aug 29, 2011.
  1. captw900
    captw900 Light Load Member
    174
    47
    Aug 22, 2011
    buffalo,Ny
    I need one moor post to do pms so are they worth the cash or should I look for a glass full top for me w9 im pulling a box with a mid roof 72
  3. Passin Thru
    Passin Thru Road Train Member
    1,918
    565
    Mar 8, 2007
    VA
    Yes or no depending on how much fuel it ends up saving. Don't know how you drive or how big an engine you have or if you run SW where it gets really windy. If you ahve smooth sided trailer or ribbed can make a difference. Put one on and then tell us.
  4. Semi Crazy
    Semi Crazy Road Train Member
    3,033
    2,044
    May 13, 2011
    Middle Tennessee
    I got a firm .25 mpg increase with a Taylor wing (which is for sale sitting in my shed BTW) when I yanked a box. F-liner stand-up sleeper about as tall as a Pete.
  5. halfburn
    halfburn Medium Load Member
    547
    187
    Feb 22, 2009
    Jasper AL
    You get some wicked drag when you pull a square load like a box behind a low top truck. Anything to smooth out the flow angles has to help.
    bullhaulerswife Thanks this.
  6. captw900
    174
    47
    Aug 22, 2011
    buffalo,Ny
    Semi crazy how much and will it go on the w900 mid roof
  7. Semi Crazy
    3,033
    2,044
    May 13, 2011
    Middle Tennessee
    $500 and yes. If UR serious I'll get some good pics.
  8. captw900
    174
    47
    Aug 22, 2011
    buffalo,Ny
    Yes and yes I've got to change the mapping on the brain I don't need 550 hp in the lower gears I don't drag race in the parking lot like the noobs then id like to try the.the wing to help get air over that 3to4' sail behind me. Probably wont be able to do it till oct first but I am serious 5.8 is hard to swallow coming o out of a 6 6.7 detroit :biggrin_25510:
  9. SHC
    SHC Spoiled Rotten Brat O/O
    8,484
    7,046
    Feb 26, 2011
    Westville, IN
    I put a Taylor wing on the roof of my 99 FLD and I got a solid .5 mpg increase when I was pulling vans. And the one semicrazy is selling should be the same as long as it's for a flat top sleeper and not a stand-up/midroof truck.
    Very nice looking truck!!!
  10. Kittyfoot
    Kittyfoot Crusty Ancient
    2,092
    3,056
    Sep 21, 2009
    Sorrento, Louisiana
    captw900 Thanks this.
