Turbo whistle
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by JimMatthews89, Mar 2, 2022.
  1. JimMatthews89
    JimMatthews89 Bobtail Member
    7
    Mar 24, 2015
    I have a 2017 Kenworth T680 with a Cummins ISX 15 550 hp engine. I have a whistle in my turbo. The whistle is at idle and with increased RPMs. What's weird is, it goes quiet after about 10 minutes at idle. I also noticed, while it's whistling at idle, my idle usage shows 2 gal/hr. But when it shuts up, idle usage goes down to .8 gal/hr.
    Neither I nor several mechanics can find an exhaust leak. Turbo is dry, with no play, and turbo psi is working normally. ( 20 psi on small grades up to 40 psi on large grades depending on the load).
    After long periods of driving, when I come to a stop, sometimes it will be squealing other times it won't. This is driving me insane. When it squeals, it is so loud you can here it across the parking lot. Not a single mechanic I've taken it to can figure it out. Thanks in advance!
  3. Hulld
    Hulld Road Train Member
    2,882
    6,564
    Oct 19, 2015
    Upstate NY
    Sounds like it might use a VGT turbo and it’s worn or sticking?
    Oxbow and Bean Jr. Thank this.
  4. okiedokie
    okiedokie Road Train Member
    11,712
    84,887
    Jun 13, 2011
    PNWET
    Leaking gastket...usuallly under the EGR?
    Oxbow Thanks this.
  5. Petegraintrain
    Petegraintrain Bobtail Member
    30
    4
    Sep 29, 2018
    Is this truck egr deleted? Might be switching to the wrong operating mode. Trying to warm up a non existing SCR can
  6. Goodysnap
    Goodysnap Road Train Member
    3,694
    8,948
    Jul 12, 2017
    You likely have a cracked exhaust manifold gasket just starting to leak. When the turbo changes exhaust back pressure the noise can change and or go away. the noise is the exhaust leaking by the bi-metal manifold gaskets as they are cracked and vibrating. Inspect closely for small soot trails exiting the manifold at the cylinder head. Most often #2 or #5 but could be others as well.
    Find a shop with a smoke machine and leak check the hot side of the engine and the leak will show its face.
    PumpkinOvalHead and Oxbow Thank this.
  7. JimMatthews89
    7
    Mar 24, 2015
    Any recommendations for a good shop that won't rape me in labor? I've had my fair share of bad ones.
  8. JimMatthews89
    7
    Mar 24, 2015
    This is what it looks like.
  9. Goodysnap
    3,694
    8,948
    Jul 12, 2017
    I see some staining on the EGR pipe. Looks like something may be leaking from above out of the picture.
    Nothing immediately concerning that I can see.
    Truck repairs are expensive. Most dealer door rates are closing in on or at 200hr. What area do you frequent?
