Turbo shaft play?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Cat sdp, Aug 1, 2014.
  1. Cat sdp
    Cat sdp . .
    20,819
    71,604
    Apr 8, 2012
    Orion's Belt
    Anyone know what the spec is for a cat c-15 turbo shaft play? Both turbos have a little play in and out. Not side to side.....
    Exhaust manifold took a dump..... So here I am.....
  3. JohnP3
    JohnP3 Road Train Member
    1,594
    683
    Feb 21, 2010
    Rock Creek B.C. Canada
    If you pull and or push on the shaft and it does not squeal, then it is perfect.
    Just a thought!
    Cat sdp Thanks this.
  4. Heavyd
    Heavyd Road Train Member
    7,749
    6,184
    Feb 4, 2009
    Yep, just make sure the fins cannot scrape the housing.
  5. Cat sdp
    Cat sdp . .
    20,819
    71,604
    Apr 8, 2012
    Orion's Belt
    Tks.... I thought there was a actual measurement . Got a call into the local cat house, but I was to late ( Friday afternoon). Will find out Monday .
    And no they don't scrape the housing....
    Cat guy called me back (and on a Saturday) there is no published number on shaft play in/out. But he said a new acert turbo will have 3/1000 play and at 8/1000 you should start to think about replacement .....
    Mine are 6 and 7.... I'm going to put them back on and check play regularly ..... He agreed with this plan.
    There on the short list......
