Turbo Boost
Discussion in 'Ask An Owner Operator' started by Lefty0061, Sep 29, 2022.
  1. Lefty0061
    Lefty0061 Bobtail Member
    11
    Sep 29, 2022
    Can anyone help me out, I have a 2013 Coronado glider kit with a 1999 dd4 12.7 liter engine that came from Detroit as a 500 hp reman engine. I had this thing tuned by Pittsburgh power an set at 600 hp a few years ago. I just had it reprogrammed to a 550 hp. I'm running a 171702 bw non waist gated turbo & just switched to a bw k31 turbo. I can not get over 30 pounds of boost, I've tried & tried for years, I'm told I should be putting out 34 to 40 lbs of boost, on a hill or a pull it falls flat on its face. I'm running a 13 speed with 3:55 rear ends. Can anyone help ?
  3. ProfessionalNoticer
    2,941
    7,852
    Apr 25, 2021
    Stop getting ripped off by Schittsbirgh Plower and take it to Antrim Diesel. They'll straighten it out for you.
    Roger McG and Long FLD Thank this.
  4. nikmirbre
    nikmirbre Road Train Member
    5,376
    9,581
    Jul 27, 2011
    High Point NC
    That the place in greens castle PA?
  5. ProfessionalNoticer
    2,941
    7,852
    Apr 25, 2021
    Yes, sir.
  6. Diesel Dave
    8,526
    23,505
    Jan 20, 2010
    Hesperia, Ca.
  7. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,056
    Nov 18, 2014
    Land of local
    Antrim or Fernando at DCS. What boost were you making with the 702?
  8. Lefty0061
    11
    Sep 29, 2022
    OK thanks
    ProfessionalNoticer Thanks this.
  9. Lefty0061
    11
    Sep 29, 2022
    Ya Greencastle, Saxonburg
  10. little cat 500
    2,044
    1,090
    Jan 17, 2010
    Abbottstown PA
    k31 is garbage 30psi 171702 should be up around 35 38 psi you probably have a boost leak in the ATA
  11. Lefty0061
    11
    Sep 29, 2022
    Both 600 hp with 1702 30 psi, now 550 hp with k31 28 to 30 psi. Basically falls flat on its face in a pull or anytime I need power
