Turbo Boost Gauge Question
Discussion in 'Trucks [ Eighteen Wheelers ]' started by MichaelP, Oct 30, 2011.
  1. MichaelP
    MichaelP Bobtail Member
    34
    Aug 19, 2011
    Mayfield, KY
    First off let me start by saying I did a search and did not find a answer to my question. I have w900l we have recently installed a turbo boost gauge in and when the boost starts to build the needle will viberate rapidly. It will not start to viberate until it gets above 15psi and continues all the way to 30 psi. The motor is a 5ek cat.
  3. Oscar the KW
    Oscar the KW Going Tarpless
    12,246
    28,114
    May 19, 2011
    Try a different gauge. I put one in a freightliner years ago and it did the same thing. Got a different gauge and problem solved.
  4. V8Lenny
    V8Lenny Road Train Member
    1,016
    130
    Aug 3, 2008
    Europe
    Use a very small rstrictor in the line before the gauge, it helps smooth the pulsing of the charge air. Better gauges have liquid filling to damp the vibration.
  5. JohnP3
    JohnP3 Road Train Member
    1,594
    683
    Feb 21, 2010
    Rock Creek B.C. Canada
    If you put on a 1/8 air line to the gauge, it helps,as does putting the hose into the intake elbow, but as stated, oil filled gauge is the best.
  6. Smaggs
    Smaggs Pie Crust
    1,405
    693
    Apr 12, 2011
    Pittsburgh, PA
    oil filled gauges are awesome for pressure reading applications. They reduce vibration for a more accurate reading.
    I don't know what they do for the volvo 670s, but my gauge never wobbles. Might be digital, if that's possible. I don't know much about modern gauges. I'm talking regular, good old 'analog' gauges, most likely like the one you're describing.
    Good luck and let us know how it goes.
  7. MichaelP
    34
    Aug 19, 2011
    Mayfield, KY
    I agree 100% that liquid filled gauges are the best, but I want all my gauges to match I know that probably sounds stupid to some but it would drive me crazy to look at a mismatch gauge. I have to take a closer look at the line we have had 10 cats all with boost gauges and this is first one to have this problem. The gauge is less than a year old from KW may be a bad gauge thanks for all the replies
  8. dave26027
    dave26027 Road Train Member
    1,284
    804
    Sep 10, 2009
    Dallas, Texas
    Mounted too close to the intake valves. There might be another hole to use closer to the air-to-air cooler.
  9. Don2WS
    Don2WS Medium Load Member
    306
    26
    Feb 26, 2010
    Sturtevant WI
    my truck had the same problem picked one up from scrapyard because KW wanted 145 for the gauge $15 and its still working after two years
  10. MichaelP
    34
    Aug 19, 2011
    Mayfield, KY
    Yea I don't understand why parts are so expensive for this old of a truck. I think we mounted the line in the wrong spot
  11. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,727
    Jan 30, 2010
    keep stroking.
    mine does the same thing its normal unless you do like the other post say, an oil filled gauge will settle it down.
