Turbo Blankets / Exhaust Wrap
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Jar-Head, Dec 23, 2013.
  1. Jar-Head
    Jar-Head Road Train Member
    1,358
    959
    Dec 7, 2013
    I'm wondering has anyone tried any of these products and did you see any performance increases by doing so ? I'm willing to try anything that will increase my fuel economy with at decent ROI .
    Ive heard that wrapping the manifold pipes with header wrap and wrapping the last 2ft or so of the exhaust will increase fuel mileage by retaining heat
    any insight
  3. luvtotruck
    luvtotruck Road Train Member
    1,978
    1,161
    Jul 30, 2013
    Phoenix Arizona
    Drop the speed and watch your boost! If you are going over a over pass with the cruise control on, take it off and glide over it! Also the scangauge outfit is a good way! There are guys on here that are running them and they make it better on their MPG. I wish you well.
    Jar-Head Thanks this.
  4. Jar-Head
    1,358
    959
    Dec 7, 2013
    I have the scan gauge and keep my boost low as possible
  5. AUSSIE DAVE
    AUSSIE DAVE Road Train Member
    1,032
    176
    Feb 21, 2010
    OZ - Brisbane
    Turbo blanket defiantly work to lower EGT which in turn improves fuel economy, exhaust wrap helps but its extremely marginal and really just a waste of time.
    Jar-Head and Cetane+ Thank this.
  6. wore out
    wore out Numbered Classic
    15,346
    185,316
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    I have two cats wrapped like you are talking about. We run pittsburgh manifolds on both. Changed manifold and wrapped them both at the same time. If it helped power I can't really tell. Same for mpg, what we did notice is the inside cab temp got a little better but we did it in July. Crazy as this sounds the pyro runs a little cooler on both, and you can see a big difference under the hood as far as heat stress it helped a there for sure. If I had to pull mine yea I would rewrap it just because under hood temps. But I wouldn't pull it to wrap it.
    RubyEagle and Jar-Head Thank this.
  7. Jar-Head
    1,358
    959
    Dec 7, 2013
    Does EGT = Exhaust Gas Temp ?
  8. Jar-Head
    1,358
    959
    Dec 7, 2013
    The PP turbo blanket is $327.00 there has to be a cheaper alternative JMO
  9. wore out
    15,346
    185,316
    Jun 5, 2013
    Yes EGT means exhaust gas temperature. It really takes one to be pumped up to see gains.
  10. Jar-Head
    1,358
    959
    Dec 7, 2013
    My truck is a Detroit 14.0 515 hp boost can hit 31-34 but I don't try to run it hot like that I try to keep low boost for fuel Econ
  11. Jar-Head
    1,358
    959
    Dec 7, 2013
    I typically try to keep boost around 9-12 loaded at 44k
