tuning an antenna without a SWR meter
Discussion in 'CB Radio Forum' started by corneileous, Jul 9, 2010.
  1. corneileous
    corneileous Road Train Member
    1,366
    335
    Nov 19, 2009
    Podunk, OK
    Not sure if this has been asked before but is it possible to tune an antenna somewhat close without using a swr meter? I have one of the older Cobra 25 LTD Classics with the mic plug on the side rather than the front. It doesnt have the SWR meter on the power gauge but if anybody knows, where should the power needle be when I key the mic on a properly tuned antenna? As of right know, I have a 2010 Cascadia and I'm using all factory wiring minus the passenger side antenna because it seems like i get better results because if duals need to be certain distance apart, then the duals on here arent even close to being far enough apart being mounted to the side of the sleeper rather than at each end of the mirrors. The antenna Im using is one of those fancy tunable whips that has the two rather large coils close to the base of the antenna. The overall length of the antenna is prolly 4 feet. It seems to work ok since it sticks above the cab a lot further than the short, 3 foot stockers that were on here, but it seems like it could be better if it were properly tuned. Right when I put it on, I was still able to talk to somebody fairly loud and clear with about a mile to a mile and a half of distance between us. That good? Acceptible? Need o be improved?
  3. Diesel Dave
    8,520
    23,433
    Jan 20, 2010
    Hesperia, Ca.
    I always recommend the FRANCIS antennas. You need no SWR checked and they work GREAT. And they're VERY AFFORDABLE.
  4. corneileous
    1,366
    335
    Nov 19, 2009
    Podunk, OK
    Even on a system that has factory wiring and mounts and with one of them multiplexer boxes that splits the AM/FM radio signal from the CB signal?
    I got nothing wrong with Francis, but this antenna Im using now was free. Does Francis make Antennas that arent made with a fiberglass shaft? The reason for asking is because since I chose to use the factory mounts, a four-foot antenna mounted in that spot would probly be takin out low-flyin aircraft, if ya know what i mean and with the style of antenna I have, its one of those flexible wire whips that has a lot more give in it.
  5. corneileous
    1,366
    335
    Nov 19, 2009
    Podunk, OK
    Besides, I was still hittin an occasional limb or two with the 3-footers I had on here before.
  6. WA4GCH
    WA4GCH Road Train Member
    3,324
    577
    Aug 12, 2009
    Seminole Florida
    Yes you can tun with a noise bridge such as a Palomar RX-100 or the some of the new analizers.
  7. Powder Joints
    7,506
    7,414
    Sep 25, 2007
    Rosamond, SoCal
    You can use a ohm meter, but this just checks the end to end properties for opens and shorts. You really need to use a SWR ( Standing Wave Ratio) to check the install. Francis is a good antenna, the factory harness who knows. If all else fail install the radio and antenna and stop by the local cb shop, most will check the install free.
    If the RF meter pegs out dont use the radio till you get it checked.
  8. SoulSeeker
    SoulSeeker Light Load Member
    153
    Nov 16, 2009
    Houston, Tx
    One question about the Francis antenna, I want to know the difference between the Francis tunable antenna and the regular Francis antenna, I saw an ebay auction listing a Francis 300 w tunable cap antenna, can someone give me the info on these two antennas.
  9. Powder Joints
    7,506
    7,414
    Sep 25, 2007
    Rosamond, SoCal
    The coils in the non-tunable run from bottom to top length wise. the way they do it makes it a 5/8 wave antenna.
    The tunable I believe is a 1/4 wave antenna that is wound conventionally simular to the firestick.
  10. WA4GCH
    3,324
    577
    Aug 12, 2009
    Seminole Florida
    A 5/8 wave on CB would be 21 foot tall ....
  11. SoulSeeker
    153
    Nov 16, 2009
    Houston, Tx
    Is there any difference on performance?
    Is it just the same besides the size is the only difference?
