Tuning 3406E
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Yoshi470, May 13, 2020.
  1. Yoshi470
    Yoshi470 Bobtail Member
    6
    Hello All, first time poster here long and had a few questions on tuning/re rating my 1LW 3406e engine. It’s currently set at 475 as far as my knowledge goes. I ran the the overhead on it today and looked at the injectors and they are part #1408993. Ive heard a lot of talk about “57” “58” injectors. Just curious what category my injectors fall under? Looking to add around 100hp or so. I’ve read that the older 40 pin ECMs can be hard to tune and sometimes you ruin them trying to tune/re rate them. And idea what the best route to go would be to get another 100hp or so? Thanks!
  3. lynchy
    lynchy Light Load Member
    180
    842
    Oct 18, 2010
    off the grid
    Followed this guy on u tube a while,knows his stuff?
  4. Yoshi470
    6
    Does anyone have access to a pre low nox 550 file? I believe the flash file number I’m looking for is 1708226. Thanks
  5. Yoshi470
    6
  6. aaronpeterbilt3787
    aaronpeterbilt3787 Medium Load Member
    699
    1,077
    Apr 2, 2016
    Where are you from? I know a guy, but he’s in Ontario Canada.
  7. Yoshi470
    6
    I’m from Wisconsin. Is it possible to even put an older pre low nox file flash into the ecm? I’ve read it’s difficult to get those older flash files to upload once a newer low nox files has been uploaded.
  8. lester
    2,914
    7,842
    Jan 2, 2012
    NW, Iowa
    No a 1LW is no problem
  9. Kw t2000 cat
    Kw t2000 cat Bobtail Member
    Hi I'm Costa Rica
    I own a 475Hp 1750 torq 3406E 1LW 25991
    The question is: Does this engine has a Low Nox in the ECM already?
    If so does this files cause to derate the hp while driving?
    Long story short: The truck sometimes feels and shows good power 30psi on turbo but sometimes it only gets 22psi no matter what I do or how I drive it...
    Infrared gun shows 140° fuel temp on the tank surface
    No check engine light on
    6999 trim codes installed
    A bit of black smoke
    New turbo
    I haven't measured fuel pressure yet
    Thanks from Costa Rica
    Stay safe,be safe,drive hard...
