I have a choice to make and I need help. I have the option of buying two radios and a kicker(Palomar 250). The cobra 29 ltd classic has a "super mosfet tune and a upgraded final with a swing kit. That all sounds good and what not but WHAT does all that mean? I like a good talking CB just like the next guy but is this all just chop work or is it real work to make it really talk? Then there's a completely stock galaxy 959. No peak and tune.. Nuffin. Stock as the day it was made.
I plan to buy a radio, run it for a bit then send it off to a shop to have the CB matched to the Palomar. The cobra will run me 97 bucks and the galaxy 117. Both in good condition. So which radio sounds like the best deal?
Tuned cobra 29 or stock galaxy 959?
Discussion in 'CB Radio Forum' started by Dark_Majesty_06, Jun 6, 2014.
Sorry, on the cobra 29 its a 520 mosfet super tune and swing kit installed. Regular final should still be in there.
My suggestion would be to have the Cobra returned to stock so that the deadkey is within the limits set by the Palomar, and to *remove* the swing kit. If your barefoot signal is non-linear already (as a swing kit will induce), then using that as the input to an amplifier, *especially* one with no input or output tuning, the trash from the Cobra will just be stronger, ergo louder and heard farther away, both in distance and number of channels it occupies.
I'd take the money you can recover from having the Cobra made to stock again, set aside the Palomar, and put the money you have left over into increasing the counterpoise for the antenna on your vehicle so that you can approximate a resonant 50-ohm load for the radio. If you're in a plastic cab, even just using rubber cement to bond aluminum foil to the inside of the roof (or copper foil if $$$ is no object) and making sure the "ground" side of the antenna mount makes good contact with the foil, f'r instance with a couple of long-ish bolts, fender washers against the foil, then a lockwasher and regular nut.
If you're blessed with a metal roof, put the tallest antenna you can fit (per either the law or the overpasses you must be able to clear) in the center of the roof. You'll be miles ahead of where everyone with the Super Whizbang 9000 watt amp and oversized coax to a pair of bullhorned whips 5 feet apart and mounted to the window mounts on a Fibreglas® cab.
Galaxy used to make decent ham gear, but current users of their CB line seem to acknowledge that the oversized meter is offset by mechanical weaknesses, i.e., a tendency to rattle apart when subjected to the stresses of the roadways. I find the Cobras easier to operate without taking my eyes off the road, but I also operate a Morse key strapped to my leg, so my frame of reference may be somewhat different than most.
Ya spends yer money and ya takes yer chances....but you can't cheat physics.
73 -
Well now that I got this Palomar amp.. This thing is way to big to be in my century. So what would a working Palomar 250 elite sell for? I'm not looking to make a gold price but just enough to help fund a new CB for me.
Mayhap someone more knowledgeable in the wide & wonderful world of marginally performing (yet patently unlawful) stuff for sale who can at least give you a starting point for a price tag.
Hope I didn't spoil the experience for you; life *can* be fun without an amp as long as your signal is clean and, most importantly, you have a solid antenna system.
Hope to work you farther down the log. If you get to where I-40 crosses I-77, give a yodel for Handlebar.
73 -
Will do. I honestly think that's what im going to do. Just stay barefoot and be happy. I have a few radios to choose from and one of them are a connex 3300. I've read many many good things about these. I have a predator 10k and have a ground strap that allowed me to get my swr down below 1:5. So antenna is in good condition. So ill just transmit and be happy I can get out across the median!
I just wish I knew the cobra was done right. I read that if those super tunes aren't done right.. It'll sound worse than a stock radio. So im a little worried. I've always wanted a connex 3300 and a galaxy 66. Have a chance to get any one of these radios. I guess some guy is selling his collection locally. His prices are very fair. I just can't make my mind up. I just want a strong radio I can be proud of and enjoy. -
Personally, I'd stay away from any radio with a so-called "swing kit".
handlebar, Dark_Majesty_06 and Big_m Thank this. -
I hear ya. I think ill have him let me hear the connex and galaxy 66 and choose one of those. Thank you.
An over-modulated "swing kit" radio and a splatter box together spells lots of harmonic interference... Would love to see that combo on a spectrum analyzer LOL
Just a caution to be aware of as you go shopping.
73 & good luck with your purchase.darthanubis Thanks this.
