Tu-flo 550 500-2032 popping off
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by greaseburner, Apr 3, 2019.
  1. greaseburner
    greaseburner Light Load Member
    155
    45
    Builds pressure fine. No oil at pop off on dryer. Once built up, the little pop it valve starts going off every 10 seconds or so. The pop off on the dryer gies off at about 125 psi. Which ya guys think? Thanks
  3. BoxCarKidd
    BoxCarKidd Road Train Member
    4,418
    6,432
    Aug 26, 2014
    Where is the little pop off located that goes off every 10 seconds?
  4. greaseburner
    155
    45
  5. BoxCarKidd
    4,418
    6,432
    Aug 26, 2014
    Search block: Compressor popping.
    Might also unbolt governor from compressor. Does it send air to compressor at cut out pressure? Is the passage in the head coked up.
    Repair the unloader in the compressor or just replace the unit. Just my opinion.
    062 Thanks this.
  6. Rideandrepair
    17,214
    55,886
    Aug 8, 2015
    Looks like you put a new safety valve already, is it the right one, must be rated higher than govenor setting. Replace govenor yet. Use new one, rebuilt ones aren’t worth a crap.
    roshea Thanks this.
  7. greaseburner
    155
    45
    it's rated for 250 psi. nope, but will be in a lil'bit. but since that's going off at 250, the truck shows 125 how could it be the governor? Also picked up a head kit.
  8. spsauerland
    spsauerland Road Train Member
    4,296
    10,886
    May 31, 2010
    West Harrison, In
    Restricted discharge hose or plugged up drier will also cause safety valve to open.
    SAR and 062 Thank this.
  9. Working2party
    Working2party Medium Load Member
    608
    729
    Feb 10, 2018
    Kansas
    The truck is reading 125 from the primary and secondary air tanks. You have a restriction between the compressor and the check valves mounted in the inlets of each air tank
    Usually on older model trucks the air governer is fed from the wet tank. (Newer models are fed from the air drier.)
    So knowing all that. (With new releif valve in place)
    If you have one problem, it’s a restriction either in the oulet of the compressor (valves in head gummed up), restricted / kinked/ plugged compressor to drier line, or a plugged restricted air drier.
    Most older model truck can have the air drier routed around pretty easy. Try that first.
    Next most probable is a gummed up valve in the compressor head
    But I would check the air line for restriction second, cause it’s easier than the head.
  10. Rideandrepair
    17,214
    55,886
    Aug 8, 2015
    Pop off valve is to protect head gasket from blowing, without it head gasket usually will blow.Sounds like head gasket is fine.Govenor is cheap. So it builds up and drier spits at 125, then continues to build to 250 then safety valve starts spitting? I would change the govenor first, and check the discharge line for swelling inside while it’s disconnected
  11. Working2party
    608
    729
    Feb 10, 2018
    Kansas
    If the air drier spits at 125 then the Governor is working properly. The Governor only “asks” the air drier to spit and the compressor to shut off at the same time. You could still have a gummed up unloader not letting the compressor shut off, but that air would be puffing out of the air drier.
    It’s not your Governor.
    You have sometime blocking the air from getting out of your compressor, that can be IN the compressor head, in the air line running to the air drier, or a plugged air drier cartridge.
    I’m betting it’s a gummed up outlet valve in your compressor , could still be a plugged air drier cartridge. And there’s a slim chance of a plugged comp to drier line.
    Check the easy stuff then remove your comp outlet line, spray a fluid in it ( brake clean, penetrating oil, etc. put it back together and see if it’s better, if it is figure out how to get the outlet valve out and give it a good cleaning.
    Rideandrepair Thanks this.
