Trying to run a little quieter.
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Brooker, Apr 7, 2018.
  1. Brooker
    Brooker Bobtail Member
    15
    Apr 7, 2018
    Nova Scotia
    IMG_20151213_193145_edit1.jpg My W9 is simply too loud with the supposedly quiet inserts in the middle spools. This is an 8" over the frame application with 52" stack tops. There is no room to install a resonator between the engine to the Y pipe. Whereas there isn't room to put a complete insert in the curved tops, do you think it would help to cut an insert 38" L in two an insert each half in the top stacks?
  3. Rolling18
    Rolling18 Light Load Member
    170
    34
    Dec 11, 2008
    Portland, OR
    Agreed! mine is wayy too loud w/ the dual stacks (day cab) i'd like to see if I could get away with running just one with a larger diameter on the pass. side only... hmmm
  4. Brooker
    15
    Apr 7, 2018
    Nova Scotia
    Thanks I tried another short baffle in the tops seems to be bearable now. lol
    Rolling18 Thanks this.
  5. Brooker
    15
    Apr 7, 2018
    Nova Scotia
  6. Brooker
    15
    Apr 7, 2018
    Nova Scotia
    My 96 KW has an air leak thru the exhaust port on the firewall if you apply foot pedal. This is only when the park brakes are applied. Any suggestions?
