Truck won't perform parked regen, trying to get home
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Derov, Oct 24, 2012.
  1. Derov
    Derov Light Load Member
    64
    14
    Sep 18, 2011
    As the title says, I'm broken down on my way home. I've spent the last 3 days fighting with my company over getting me home for an important doctor appointment on the 26th in NJ. I FINALLY got a load, after threatening to quit, to get me out of California and I get to UT and the truck runs into problems.
    Symptoms:
    *The MIL came on, which didn't seem like a major concern, I'd have it looked at when I got home.
    *The Check Engine light came on, uh oh. From what I remember, this means I need to perform a parked regen. The truck refused to do a manual regen.
    *The Stop Engine light (red light) has come on and the truck absolutely refuses to regen.
    I've tried everything I know to do:
    I've shifted into gear and back into neutral, deactivated and engaged the parking break, depressed the clutch twice and the brake pedal twice, and held the Regen switch for the required 5 seconds. I've done this in various combinations all to no avail. I'm desperate.
    Freightliner Cascadia '11
    Any tips, ideas, or help of any kind would be appreciated.
  3. Cat sdp
    Cat sdp . .
    20,819
    71,604
    Apr 8, 2012
    Orion's Belt
    I feel your pain, did you try turning the key off for a couple of minutes and then restarting the truck. If the stop engine light is stuck on sounds like a tow truck might be in order. And rebook your apt now.
  4. Derov
    64
    14
    Sep 18, 2011
    It looks like a tow might be our only option, and there's nothing around here so who knows where we'll end up.
    I tried a few days back to reschedule, but I won't be able to get in for another 3 weeks. It really just pisses me off that I give 2 weeks notice (as the company requires) and the best they can do is a last minute race across the country under threat of quitting that leaves no room for delays, like this one. I wonder what would happen if I started listing my ETA to consignor as 'whenever it gets there'?
    Badmon Thanks this.
  5. truckmechanic
    truckmechanic Medium Load Member
    534
    140
    Jan 14, 2012
    Hi Desert Ca
    Gonna have to take it to a shop and have it hooked to the computer usually when this happens the Dpf is plugged with soot or one of the sensors thinks it is.a trick that sometimes works OS to pull the exhaust off where it goes into the Dpf unit just make sure to unplug the doser injector right at the back of the turbo.
    x1Heavy Thanks this.
  6. magoo68
    magoo68 Road Train Member
    3,393
    5,384
    Jun 11, 2011
    st malo mb canada
    u check fluids that doesnt sound like a regen required stop engine light id check antifreeze level and oil ps u cant do a regen unless it asks for one .
    Getsinyourblood Thanks this.
  7. magoo68
    3,393
    5,384
    Jun 11, 2011
    st malo mb canada
  8. truckmechanic
    534
    140
    Jan 14, 2012
    Hi Desert Ca
    If the Dpf becomes plugged or the pressure sensor fails and tells the ecm and the ecm can derate of #### it down depending on what its told you can try and unplug the main connection it will be right above the Dpf and try that it might get you home
  9. Sako3006
    Sako3006 Bobtail Member
    48
    13
    Oct 3, 2011
    Southeast
    Symptoms:
    *The Malfunction Indicator Light or MIL simply states that you have a malfuction in the engine
    *The Check Engine Light does not mean that you need to automatically do a parked regen. If you can't get the exhaust temps hot enough, the truck will not regen under any circumstances.
    *The Stop Engine Light is on because I'm betting that a sensor on the exhaust side is not allowing the temp to go above the required level to activate the manual regen.
    - It doesn't sound like a DPF problem necessarily, but more of a sensor issue. Is the truck being derated when the lights are on? Good luck getting home my man...
  10. Gear head
    Gear head Medium Load Member
    532
    91
    Apr 1, 2012
    Belair,md
    Im guessing its detroit?
    TomOfTx Thanks this.
  11. inktoxicated
    inktoxicated Light Load Member
    239
    50
    Apr 1, 2010
    south brunswick nj
    i was driving a rental cascadia and the red light came on and the mil. then the red light flashed and shut me down compleltey after it only allowed me to do like 10 mph for a short time. low on coolant .. whoops.. :)
