Truck won't hold high idle?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by RERM, Aug 11, 2016.
  1. RERM
    RERM Road Train Member
    1,683
    1,124
    Dec 13, 2012
    Chicago, IL
    As I sit here it's 95degrees, and as I freeze in my AC cooled cab, my truck came down from 900 rpm to normal idle.....I bumped it up again, and after about a minute or two, it came back down...,.any ideas????
    Oil temp, water temp and oil pressurevare all normal.......
  3. Heavyd
    Heavyd Road Train Member
    7,749
    6,184
    Feb 4, 2009
    Clutch pedal vibrating, on off switch partially shorted, sticky park brake sensor or brake application sensor. Anything that can cancel cruise can also cancel high idle setting.
    BoxCarKidd, j_martell and SAR Thank this.
  4. RERM
    1,683
    1,124
    Dec 13, 2012
    Chicago, IL
    Well, I changed out the clutch return spring last week, so maybe a sensor???
  5. Roberts450
    Roberts450 Road Train Member
    2,237
    3,635
    Feb 6, 2016
    Yea check that sensor. My pete was doing that and the cutting out the jake unless I pulled up on the clutch. Found the mounting screws had come loose for the switch under the cab.
