Truck won’t turn on
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Daniel.U, Oct 2, 2020.
  1. Daniel.U
    Daniel.U Bobtail Member
    4
    I have a 2015 Freightliner cascadia with ulstrashift trans, truck was working fine yesterday but this morning I went to turn it on and it gave me a couple codes and it wouldn’t turn on
    Codes:
    SPN 639 FMI 9
    SPN 560 FMI 9
    SPN 523 FMI 9
    SPN 84 FMI 19
    SPN 84 FMI 4
    can anyone help direct me to the problem?
  3. Judge
    84,396
    Detroit or Cummins?
  4. Daniel.U
    4
    Detroit
  5. Judge
    84,396
    639-FMi 9 is power supply to ECM disrupted.
    I’d start there.
  6. Daniel.U
    4
    Would you know how I can trouble shoot it also said drive shaft was engaged I don’t know if the XY shifter got stuck in gear but I had put it in neutral once I turned it off
  7. Judge
    84,396
    Unhook the batteries for a couple minutes on autos.
  8. Daniel.U
    4
    I did that but still gives me same codes
  9. Judge
    84,396
    Daniel.U Thanks this.
  10. drive-away2020
    drive-away2020 Light Load Member
    68
    260
    Aug 17, 2020
    If your having power supply issues to the ECM, it will try to start all day but never turn over.
    On Cummins there’s a power wire from the battery into the OEM side of the ECM harness. On Detroit it may be a little different. Usually when it’s an ecm power supply issue the abs light and the check/stop engine light all come on together. That’s because there’s a disruption of power to the computer that controls those things!
    start here, find the disruption of power, look good and hard to see if there is an external wire that comes from the battery to the ecm for power. This can usually be identified by the in line fuse close to the batteries and then by looking at the direction the wire goes once it leaves the box. These lines can become ice blue with corrosion over time and cause major resistance resulting in power disruption. You’ll have to peal back the wire loom and inspect. Test the fuse on that line if you got one.
    you’ll have to pull the plug part of the harness from the ecm, figure out which pin provides 12v power to the computer and test for power with the key turned in the ACC mode.
    but before you do this, I would test EVERY fuse in your fuse panel. Especially the ones dealing with ignition and etc
  11. magoo68
    magoo68 Road Train Member
    3,393
    5,385
    Jun 11, 2011
    st malo mb canada
    Whisper to it with a sexy voice. Jk battery off for 30 minutes often does help though .
