Truck tread depth
Discussion in 'Motor Carrier Questions - The Inside Scoop' started by Chadf652, Mar 15, 2023.
  1. Chadf652
    Chadf652 Bobtail Member
    47
    22
    May 2, 2018
    Hi guys,
    My company truck rear tires are currently at 4/32. My question is will Indiana DOT ground the truck if the tire tread is 2/32 on ANY of the tire grooves or would it have to be 2/32 across the whole tire?
    I’ve notified my supervisor 3 weeks ago the tires are 4/32 and he’s yet to even take the initial first steps of getting a quote on tires. He has a reputation of not wanting to put any money into the trucks and it’s like pulling teeth to get any truck maintenance done. So the reason I’m asking if DOT will ground the truck at 2/32 tire depths regardless if it’s one tire groove or evenly worn 2/32 all the way across is because I have my suspicion that the tires won’t be replaced when they reach 2/32. At that point he’s going to put me in a position where I’ll have to refuse to drive the truck, regardless if he threatens termination or what not.
    Thanks fellas.
  3. Cat sdp
    Cat sdp . .
    20,819
    71,604
    Apr 8, 2012
    Orion's Belt
    Any one spot…..2/32 rears or trailer
    4/32 on the front, any one spot
    Bean Jr., Dennixx, bzinger and 4 others Thank this.
  4. Concorde
    Concorde Road Train Member
    4,339
    15,390
    Jun 29, 2016
    West Melbourne Florida
    Those tires must be fun in the snow.
    I would just find another job, but that’s me and my miserable demeanor :)
    bzinger, rockeee, D.Tibbitt and 2 others Thank this.
  5. kemosabi49
    10,435
    44,376
    Jan 13, 2013
    SW Arkansas
    2/32" is the legal minimum. Any less is OOS.
    from 393.75:
    (b) Any tire on the front wheels of a bus, truck, or truck tractor shall have a tread groove pattern depth of at least 4/32 of an inch when measured at any point on a major tread groove. The measurements shall not be made where tie bars, humps, or fillets are located.
    (c) Except as provided in paragraph (b) of this section, tires shall have a tread groove pattern depth of at least 2/32 of an inch when measured in a major tread groove. The measurement shall not be made where tie bars, humps or fillets are located.
    I would be finding a new job asap, before you actually have to refuse to drive the truck.
    Bean Jr., Concorde and Siinman Thank this.
  6. Siinman
    Siinman Road Train Member
    5,156
    12,909
    Mar 5, 2017
    Kansas City, MO.
    Find another job if they are that picky on tires in the winter time. But to answer your question any area of the tire on rear and trailer need to be replaced at 2/32" and 4/32" on front tire. I never come close to this but it is the law.
    bzinger Thanks this.
  7. Mnmover99
    Mnmover99 Light Load Member
    248
    341
    Oct 22, 2022
    The measurement should be across the 4 wear bars of the tire, not just one side or the other.
  8. Diesel Dave
    8,516
    23,380
    Jan 20, 2010
    Hesperia, Ca.
    Time to move on to another company.
    bzinger and Siinman Thank this.
  9. PaulMinternational
    PaulMinternational Road Train Member
    1,107
    5,472
    Aug 23, 2022
    Tire don’t make the inspection, truck or trailer don’t move! That’s my philosophy. Monday I refused to haul a load until the tires were changed on the trailer. I was actually shocked the previous driver hauled it in one tire was completely bald.
    Siinman Thanks this.
