Truck Trailer Requirements for Road Test?
Discussion in 'Trucking Industry Regulations' started by Kansas, May 8, 2011.
  1. Kansas
    Kansas Road Train Member
    2,541
    2,585
    Apr 14, 2009
    aircap, Ks.
    Need some help here folks. Ive been asked to help set up a truck specifically for taking CDL Road Tests to gain a CDL A.
    Are there specific minimum length requirements for the trailer? Just as long as its got air brakes? How about a 20' container chassis, will that work?
    Can a medium duty 26K truck be used as well?
  3. American-Trucker
    American-Trucker Road Train Member
    10,371
    5,085
    Nov 8, 2009
    Charlotte, North Carolina
    why would you want someone to test in a little truck if they are going to get into a Sleeper with a 53' trailer?
    American Trucker
  4. truckerx1
    truckerx1 Light Load Member
    177
    148
    Nov 16, 2009
    As long as it is a combnation vehical with air brakes you are good to go. A medium duty truck (26,001 k )
    can be used as long as you have a trailer and air brakes.
  5. Hardlyevr
    Hardlyevr Road Train Member
    3,270
    2,538
    Jul 30, 2009
    Mapleton Depot,PA
    If your testee is used to backing up a 53 footer, a 20 foot container will make them look like a fool! Don't ask me how I know this!
  6. Allow Me.
    10,642
    12,100
    May 28, 2009
    Rancho Mirage, Ca.
    I don't think a container chassis is big enough, weight wise. I believe the front box of a set of doubles is good enough. The front trailer of a set of bottom dumps is OK in Ca. Class 8 and 7 power for sure. Best to use a day cab and 27' pup. (flatbed if possible).
  7. Kansas
    2,541
    2,585
    Apr 14, 2009
    aircap, Ks.
    Who said they were getting into a sleeper truck with a 53' trailer? I certainly didn't...
  8. High Desert Dweller
    High Desert Dweller Medium Load Member
    431
    389
    Jan 29, 2009
    The trailer must be rated at 10,000 GVWR or higher. Length doesn't matter. If Power unit does not have air brakes and is not rated to haul a trailer heavier than 10,000 GVWR, restrictions will apply.
    Kansas Thanks this.
