Truck to buy for hotshot? F-350 or Freightliner M2?
Discussion in 'Expediter and Hot Shot Trucking Forum' started by GATATransport, Jul 13, 2012.
  1. GATATransport
    GATATransport Bobtail Member
    7
    New to the industry. We are looking at doing hotshots and wanted some advice on what type of truck to purchase. We were dead set on a 2012 F-350 DRW until we ran across a Freightline Business Class M2 106 crew cab with the sleeper cab and hauler gooseneck hookup last weekend. Man those things are nice. Obviously we would not buy a new one since they seem to be $125,000 instead of the $55,000 for the F-350. We will be pulling a 35 ft or 40 ft flat trailer. Seems that the Freightline will be better for longevity and mpg but we will have more debt associated with that.
    Am I overlooking any trucks that I need to be considering?
    Any advice as to what to buy? Please do not bash me if I am not using the corect terminology. We are just gathering facts right now.
  3. SiUQ1
    SiUQ1 Bobtail Member
    15
    Jul 12, 2012
    INDIANAPOLIS, IN
    I would prefer the f350
    i think the '98 version has the 7.3 engine it... nowadays it's a 6.2 litre.... I like those pick ups because i just may be able to take them almost anywhere to get it serviced... unlike a larger framed truck that may cost a wee bit more for servicing.
    I hope you find that cherry you're looking for... you're gonna be hauling cars too??
    GOOD HUNTING!!
  4. WitchingHour
    WitchingHour Road Train Member
    3,424
    2,143
    Apr 1, 2011
    Broomfield, CO
    The new F350 Super Duty has a 6.7, and it can be coupled to a six speed automatic. Not a bad setup, although I didn't use it to haul anything as heavy as what you're planning on doing.
    The M2.... that would depend on the specs. I had a side gig hauling horses for a guy one.. he had an M2 with a 10 speed and a Cat... I think it was a C11, but it may have been a C10... I don't fully remember. He also had a Peterbilt 330 with a Cummins ISL and a 10 speed. They were both good for what they were used for, but it if you get one with, say, a 6.7 Cummins, C6 or C7 Cat, etc., they don't really much of an advantage over a one ton pickup, which nowadays come with motors that match the aforementioned ones in displacement. The only advantage left would be that you'd be able to get a dual countershaft transmission in the M2, but since your intent is to buy a used one, you're not going to get to have it built to specs. So if it were me, I'd have to concur with the above, unless I was fortunate enough to find a used M2 with the specs I wanted and in the kind of shape I wanted.
    SiUQ1 Thanks this.
  5. sdaniel
    sdaniel Road Train Member
    5,511
    4,420
    Sep 7, 2011
    Pelham N.C.
    The freightliner WIll out last the ford 3 to one, and first panic stop you will love the much heavier brakes. One is ment to last a million miles. Check valves of f350 6 years old with over 300 k on clock. Break in miles on the flt.
    123456 and SiUQ1 Thank this.
  6. sdaniel
    5,511
    4,420
    Sep 7, 2011
    Pelham N.C.
    The sleeper can save you many a hotel stay! Best of luck!
  7. WitchingHour
    3,424
    2,143
    Apr 1, 2011
    Broomfield, CO
    There are plenty of ways to turn a quad cab pickup into a DOT legal sleeper, as well. It can be anything from refurbishing the back of a quad cab to adding a disconnected sleeper behind the cab, or even going all-out and doing this:
    Although if I were going to that extent, I probably would opt for a Class 7/8 truck instead.
  8. SiUQ1
    15
    Jul 12, 2012
    INDIANAPOLIS, IN
    OMG!!!!!
    Yeah that's a TON of money to do that... (I'm guessing) and you should get a class7/8 SMH.... I kinda like it LOL all the benefits of a big truck, only not
  9. GATATransport
    7
    WitchingHour, what kind of fuel mileage did you see from the M2? That seems to be a large factor in what we are looking at. I know the M2 will last longer than the F-350 but cost much more to service.
  10. GATATransport
    7
    SiUQ1, we will be hauling anything that pays well at this point. We are starting out with a flatbed goodneck and may progress to car hauler if we see the profitability for us.
    First things first I guess. We have to decide on the vehicle and then find a good reliable driver.
  11. sdaniel
    5,511
    4,420
    Sep 7, 2011
    Pelham N.C.
    About 7 to 8 from both .
