Truck Tire Wear Problem..see pics
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Bill43452, Sep 24, 2012.
  1. Bill43452
    Bill43452 Bobtail Member
    34
    Drivers Side Front Drive Axle Inside Tire....anyone have any ideas what would cause this pattern?? Thanks
  3. Flightline
    Flightline Road Train Member
    2,345
    1,165
    Oct 1, 2011
    Almost There
    Rear axles out of align.
    Bill43452 Thanks this.
  4. Bill43452
    34
    that's what I was thinking, but wanted some second opinions!! Thanks so much!
  5. bender
    bender Road Train Member
    2,105
    1,352
    Jul 20, 2010
    Don't Kid Yourself
    Excessive scrub angle. Time for the 3 axle alignment.
  6. olphart
    olphart Medium Load Member
    301
    146
    Feb 15, 2009
    Minden,LA
    I would say that's a loose wheel bearing.
    bender Thanks this.
  7. Bill43452
    34
    to olphart, do you have any idea how to check that wheel bearing?
  8. MNdriver
    MNdriver Road Train Member
    7,985
    4,371
    Feb 24, 2012
    Have them do a 3-axle.
    They'll tell you if it just scrub angle or if you got a bad bearing.
  9. bubbanbrenda
    bubbanbrenda Road Train Member
    1,388
    650
    Feb 27, 2011
    Middletown,Oh.
    If you take it to a quality suspension shop they will check bearings and bushings and king pins before they align it. They wont align a truck with loose or worn parts because you'll bring it back with the same complaint you went in with.
    MNdriver Thanks this.
  10. silver dollar
    silver dollar Medium Load Member
    481
    210
    Jan 31, 2009
    Central North Carolina
    Don't mean to hijack the thread but...The front axle on my spring ride trailer is wearing this exact same way on the right and left sides.(inside edge wearing on inside tires) Rear axle is wearing smooth and even. Anyone have any ideas?
  11. bender
    2,105
    1,352
    Jul 20, 2010
    Don't Kid Yourself
    With the wear being on the inside of both left and right sides, I would check for excessive wheel bearing play and for a bent axle.
    silver dollar Thanks this.
