Truck stop microwaves
Discussion in 'Questions From New Drivers' started by dboot01, Jan 13, 2025.
  1. dboot01
    dboot01 Light Load Member
    113
    202
    Nov 8, 2021
    Are we allowed to use them for our own dishes?
    austinmike Thanks this.
  3. TX2Day
    TX2Day Medium Load Member
    613
    4,096
    Apr 24, 2023
    Texas
    Yes you are. May want to take a wet wipe with you and give it a quick clean up.
    austinmike, dboot01, tscottme and 2 others Thank this.
  4. Numb
    Numb Crusty Curmudgeon
    3,937
    8,743
    Jan 30, 2012
    Charlotte, N.Carolina
    and at least use a cover or put a napkin over it, so you don't splatter it
  5. Espressolane
    16,967
    102,253
    I would recommend that you run away from them. Just take a look inside. Probably hasn’t been cleaned since the regional manager was last at the location. Too high a risk of a food borne illness.
    If you have the space, a 2000 or 2500 watt inverter and a trip to WallyWorkd, will be a good option. Save money and time.
  6. tscottme
    tscottme Road Train Member
    You can ask the clerk if it's free or not. I did a few times until I got some signal from them they thought it was a stupid question at several places. In most places the truck stop microwave is free to use. In some places in CA I overheard the clerk/owner? telling a customer he needed to pay to use the microwave. At one truck stop, I think it was the Sumner, WA Shell truck stop I think they had a sign indicating the cost of using the truck stop. Many are neglected, some are clean. I would suggest you both put any food into a container with a cover before using it or at least use a PAPER bag with your food inside it and the end closed to no add to the chemistry experiment in the oven and keep the cooties off of your food. You can use the cheapest PAPER plates that come in a stack of 100 or more, the really flimsy paper ones, not the study one with designs on them as a bottom "plate" and a top cover, or for something like a burrito, put the burrito on the paper plate, squeeze or roll the paper plate with the food inside and slide that into a paper bag you brought from the truck.
    Remember, you don't know if that particular microwave is under-powered, over-powered, or nuclear-powered so be careful. I would advise you buy something in the truck stop as appreciation they have it for you to use.
  7. Allow Me.
    10,642
    12,099
    May 28, 2009
    Rancho Mirage, Ca.
    Much easier to eat at Subway, right ? :argue:
    Sons Hero, REO6205, austinmike and 3 others Thank this.
  8. buzzarddriver
    3,507
    10,015
    Feb 1, 2011
    Dallas, TX
    If your company won't put an inverter in your truck, you could get you one of these $350 small gas invertor generators and a $80 Walmart microwave.
    The generators are about 34# and 18"x18"x8". Set on your catwalk and run an extension cord into the sleeper to run your microwave. Then when done, put the generator in the side box, after it cools off, of course.
    Amazon.com: GENMAX Portable Generator, 2000W Ultra Quiet Gas Engine, EPA Compliant, Eco Mode Function, Ultra Light, Suitable for Backup Home and Camping(GM2000i) : Patio, Lawn & Garden
    hope not dumb twucker Thanks this.
  9. TX2Day
    613
    4,096
    Apr 24, 2023
    Texas
    Love's has a 1500 watt inverter that will power a small micro. Or a small crock pot.
    Number corrected.
  10. Frank Speak
    Frank Speak Road Train Member
    4,478
    13,665
    May 3, 2016
    You can, but why? Ain’t there any Kentuckians around?
    Sirscrapntruckalot Thanks this.
  11. tscottme
    The smallest low power microwave I've seen for sale after 1999 is 700 watts of cooking power. Meaning it requires .ore than 700 watts of electricity. No 150 watt plug-in power inverter will power a crockpot, microwave. The 150-300 watt inverters are good to recharge a laptop, battery-powered drill, electric razor. The inverter also should me pure sinewave or it will shorten the life of the transformer in the power brick that sits between the inverter & laptop.
