Truck Specs and gvwr
Discussion in 'Questions From New Drivers' started by kf4pwb, May 18, 2017.
  1. kf4pwb
    kf4pwb Light Load Member
    75
    22
    May 7, 2015
    Want to make sure I have this right.
    • The GVWR of the truck says 52,000 lbs.
    • The Front axle capacity says 12,000 lbs.
    • Rear axle capacity says 40,000 lbs.
    • 40k+12k = 52,000 lbs.
    • Max hauling on our authority is 80,000 lbs.
    • Typical tandem axle capacity on a 53' dry van is 34,000 lbs
    This means that the max we can load a trailer and be legal going down the road is the following and still not be overloading the 52,000 GVWR of the truck?
    • Front truck axle = 12000 lbs
    • Drive axles = 34000 lbs
    • Trailer tandems = 34000 lbs
    • Total weight hauled including weight of truck + weight of trailer + weight of the load = 80,000 lbs
    If I was to haul such that I was at capacity of the axle ratings of the truck and the trailer (12,000+40,000+34000 = 86000 lbs) I would be 6000 lbs over weight according to what my authority says I am licensed to haul. The truck can do the extra 6000 lbs but I cannot legally haul it.
    Correct or no?
  3. Cat sdp
    Cat sdp . .
    20,819
    71,604
    Apr 8, 2012
    Orion's Belt
    Yes....
    You would need permits to haul more weight.
    kf4pwb Thanks this.
  4. RET423
    RET423 Medium Load Member
    432
    534
    Apr 6, 2017
    Kalifornia
    Your truck has 40000 pound rears but you can only put 34000 pounds on a closed tandem regardless of the rating, you can go 40000 on a spread tandem.
    My Transfer can be legal on every axle and be 7000 pounds over on the gross at the same time.
    You can buy a permit to exceed the 80000 pound gross limit in some circumstances but it is a permit good for one load only and usually comes with specific routing instructions, when I ran lowbed I was at the permit office every day buying these.
    These are the California restrictions anyway, but there are many who think the Federal rules apply in every State, those guys get tickets in California :)
    bottomdumpin Thanks this.
  5. MACK E-6
    48,136
    219,708
    Permits for a divisable load?
    RedRover and TripleSix Thank this.
  6. RET423
    432
    534
    Apr 6, 2017
    Kalifornia
    Lowbed loads, as in heavy equipment like dozers, loaders, scrapers and graders.
  7. MACK E-6
    48,136
    219,708
    True, but the OP mentioned vans.
  8. RET423
    432
    534
    Apr 6, 2017
    Kalifornia
    Yes, that is why I said "in certain circumstances" the gross limit can be exceeded, his circumstances are not on that list.
  9. Cat sdp
    Cat sdp . .
    20,819
    71,604
    Apr 8, 2012
    Orion's Belt
    Yes, dump , tanks or flats doesn't matter....
    Toomanybikes and Ruthless Thank this.
  10. Ridgeline
    22,116
    113,354
    To the OP, you are forgetting the weight of the truck and trailer are also included in the GVWR.
  11. kf4pwb
    75
    22
    May 7, 2015
    See last bullet point in original post:
    RET423 Thanks this.
