Truck running very slow on reverse?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Xenergiserx, Jan 19, 2023.
  1. Xenergiserx
    Xenergiserx Light Load Member
    107
    60
    Feb 2, 2021
    Hello guys a have a international with a Cummins and Allison transmission automatic. Today I went to backup and the truck moved very slow. Then it would kick in fast Then Slow again. I was able to back it up very slow . The truck was in a lil bit of a incline but barely noticiable and I had 41k on the trailer.
    Don’t know if related but I can hear a boost leak. When the turbo comes on .
    But truck runs fine when going forward
    when I apply the engine break I can hear a clicking sound.
    also had a seal replaced on the trailer. When I stopped it felt hotter than the others. Not scorching hot.
  3. sirrepairsalot
    sirrepairsalot Light Load Member
    66
    28
    Aug 9, 2018
    Canada
    Sounds like a clutch pack starting to pack it in.. Hydraulic Pressure controls the engagement (and the constant engagement thereafter), to me it sounds like its having a hard time setting it and forgetting it. Try a new filter and top the fluid after, and see what happens. If it doesn't fix the problem then that clutch pack probably needs a refreshing with seals/orings as well.
    The Railsplitter Thanks this.
