truck runing with very low temperature
Discussion in 'Experienced Truckers' Advice' started by medseg2003, Oct 24, 2018.
  1. medseg2003
    medseg2003 Bobtail Member
    26
    7
    Aug 11, 2017
    hello every one
    i have 2013 freightliner cascadia isx 2250, yesterday i was driving and suddenly check engine light came up it s spn 3060 fail18. i check it online it says something about engine cooling system monitor. i also notice when i am driving the water temperature gauge is very low it s under 150 degree usually it is above 190 when i am driving normal.
    before this happen i had a problem with the coolant every 4000 miles i need to add 1 gal of coolant i look evey where i see no sign for leaks ,i took it to a shop they check it with air pressure they couldn't find any leaks also
    does any one has this problem before, also do i can still drive it even if the temperature is low
    thx for help
    Lepton1 Thanks this.
  3. snowwy
    snowwy Road Train Member
    20,527
    13,262
    Jul 6, 2009
    Yes you can drive with low temp. Should be able to anyways. Just means the thermostats aren't working. If you're sure the radiator is full. Being low on antifreeze could cause a cold reading also.
    I've been driving a w900 with bad thermostats for the last 2 years. Sometimes it sucks in the winter when going down hills. Gauge will drop to the bottom.
    medseg2003 Thanks this.
  4. Ridgeline
    22,103
    113,210
    Get it to a cummins shop, have them see what the actual temps are, you don't want to run it with low temps too long, you will build up sludge and other problems. It may be a stuck open thermostat or a sensor.
    Cattleman84 and Lepton1 Thank this.
  5. Bigrayon
    Bigrayon Road Train Member
    1,283
    646
    Aug 16, 2015
    I got my truck brand new and my gauge never work two years plus and still have not moved ones,
  6. windsmith
    windsmith Road Train Member
    7,296
    6,031
    Sep 2, 2011
    NEPA
    Get the thermostat fixed. Running cold is not good for an engine with emission controls.
  7. STexan
    STexan Road Train Member
    14,963
    29,153
    Oct 3, 2011
    Longview, TX
    On a related note. A few weeks ago running across Montana, it was around freezing but I observed 2 [newer] trucks already running winter fronts nearly full closed.
    :biggrin_25523:
  8. AModelCat
    154,267
    Either T-stats are stuck open or your gauge/sensor crapped out.
    Jazz1 Thanks this.
  9. snowwy
    20,527
    13,262
    Jul 6, 2009
    I"m gonna ask the boss about that. Since he isn't interested in replacing the stats.
  10. 86scotty
    86scotty Road Train Member
    4,373
    11,589
    Aug 27, 2017
    Appalachia
    I’d replace the boss.
  11. snowwy
    20,527
    13,262
    Jul 6, 2009
    It don't matter who you work for. It's pretty much all the same.
    Money always trumps maintanance.
    The only company I've worked for in almost 20 years that actually fixes things. Leases new trucks so repairs are under warranty.
