Truck polishing
Discussion in 'Ask An Owner Operator' started by Largecar359, Apr 13, 2013.
  1. Largecar359
    Largecar359 Road Train Member
    1,075
    1,324
    Aug 13, 2011
    New Jersey
    Hey everyone, normally on my tractors I use either speedy hand polish or I run it with the buffer wheel. Usually when I make a couple passes either cutting or polishing with the wheel I can get it to come out very nice. It takes me two weekends to do the whole truck and three trailers. My buddy just bought a tractor and these tanks and wheels are like sand paper. Right away I could tell after making a few passes that the shine is not gonna come up without sanding them. He wanted to keep polishing but I don't want him to put all that effort in and not get the right result. Has anyone sanded their tanks and wheels? How hard is it, and do you start with like 100 grit and work it to 1200?
    I realize not to many guys polish anymore but I'm sure there's a couple drivers on here that could help me out.
    Thanks,
  3. Largecar359
    1,075
    1,324
    Aug 13, 2011
    New Jersey
    O and what's your favorite polish to use? I'm thinking of trying this new Gojo, anyone have any luck with it?
  4. Ezrider_48501
    3,845
    5,130
    Apr 2, 2011
    bismarck, nd
    i have polished some pretty rough metal starting with 400 grit then 800 then 1000 followed with a cutting compound and then a polishing compound.
  5. aiwiron
    aiwiron Road Train Member
    5,927
    5,228
    Aug 24, 2011
    Sunny Tampa Florida
    Old school polisher here, I use 3M buffing compounds for my polishing. A quality wool bonnet and a buffer, small places around the lug nuts and such I use a drill and have a harbor freight polishing kit that has all the tiny spot buffing pads in the kit.
    I ran a steel hauling truck and we were in and out of mud jobs and my truck was polished all the time.
    Start off having the truck washed at a Blue Beacon or similar truck wash and have them brighten the aluminum.
    No need to sand anything, go to a body shop supply place and purchase the 3M buffing compound in red and then a white polishing compound.
    Start with the red and use just a little, work the area with the buffer and material then move on until it shines.
    After your all done with the red go back and start all over again with the white compound, once it starts looking like chrome you will have it.
    rainyday lover, FLATBED and MJ1657 Thank this.
  6. Ezrider_48501
    3,845
    5,130
    Apr 2, 2011
    bismarck, nd
    metal has to be pretty rough before you need sand paper like as in being sand blasted or rock pitted. or say if you want to polish cast alum. if the surface is smooth but dull it should polish up with a buffing wheel. the material your wheels are made out of is just as important as the compounds your using.
    aiwiron Thanks this.
  7. Largecar359
    1,075
    1,324
    Aug 13, 2011
    New Jersey
    Thanks for your help. Normally I would say I could work it without sanding and any piece of my equipment. But the truck my friend just got is in very bad shape. I'm pretty sure who ever had the truck never polished it since the thing was new. It is very rough, I can bring some shine up, however, it still feels gritty. I'm pretty sure it's gonna need to be sanded. He's gonna pull the wheels and have them machined on the high speed mechanical arm. I know that will do a great job. But the tanks,grill, and boxes are in need of some serious TLC. I'll let you guys know how it goes.
    And I'll try the compound idea thanks.
  8. CbarM
    CbarM Heavy Load Member
    894
    247
    Jan 17, 2011
    Irvine, AB
    Where is a good place to get the angle grinder lookin thing that the buffer wheels go on? I was told that a regular angle grinder is way to fast, but I cant find a lower speed on anywhere...
  9. aiwiron
    5,927
    5,228
    Aug 24, 2011
    Sunny Tampa Florida
    I use a harbor freight grinder, you can use it and not have any issues. Not the speed but pressure and working the surface across the metal so do not keep it on one spot, got to work a area like light touches.
  10. MJ1657
    MJ1657 Road Train Member
    7,521
    50,150
    Jan 28, 2012
    Isanti, MN
    Do any of them compounds work very well by hand Aiwiron?
