Truck over 26,000 Gvwr
Discussion in 'Experienced Truckers' Advice' started by Lbenzie10, Jan 26, 2020.
  1. Lbenzie10
    Lbenzie10 Bobtail Member
    6
    Jan 26, 2020
    My truck gvwr is 26,000. I weighed it today fully loaded it’s at 28,000. I do have my cdl B.
    Would I be ok going thru weight station?
    please help! thanks
  3. chriskc
    chriskc Light Load Member
    173
    366
    Mar 31, 2013
    Kansas City mo
    No you are over weight.
    Coffey and Lbenzie10 Thank this.
  4. Lbenzie10
    6
    Jan 26, 2020
  5. ZVar
    ZVar Road Train Member
    10,911
    23,825
    Sep 10, 2010
    Flint, MI
    You would be ok in regards to your license.
    You would be overweight in regards to weight law. If you pull that load regularly, you'll likely need to get a heaver duty truck. I mean if the rating is just because that's what it's registered at, simply go to DMV and get new tags. If it's what the rating for the factory is you'll need a different truck.
    Bean Jr. and Lbenzie10 Thank this.
  6. Lbenzie10
    6
    Jan 26, 2020
    It’s very rare. But I’m this case. It’s better not to go thru weighstation?
  7. ZVar
    10,911
    23,825
    Sep 10, 2010
    Flint, MI
    It's better to be legal.....
    MACK E-6, street beater and Bean Jr. Thank this.
  8. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,129
    Mar 5, 2016
    White County, Arkansas
    You are 2000 over at least. GVWR is the ruling limit for what you can put on the truck.
  9. Colt6920
    Colt6920 Light Load Member
    177
    260
    Apr 28, 2017
    Throw a hitch on it and get a utility trailer with under 10,000 GVWR.
    26k on the truck and 2 k on the trailer is ok as long as the trailer is under 10k.
    Bonus, it is still not a CDL combo. Penske rents this combo to regular Joe Schmoes all the time, car carrier trailer behind a 26k GVWR box truck.
    https://www.azlca.com/uploads/documents/04-cdl-flowchart.pdf
  10. 12 ga
    12 ga THE VIEW FROM MY OFFICE
    1,568
    1,789
    Oct 21, 2013
    Central Michigan
    If the manufactures sticker on the drivers door says 26 K you need a CDL B even if you are empty. If the truck has air brakes which I bet it does you need an AIR BRAKE endorsement.
  11. Colt6920
    177
    260
    Apr 28, 2017
    For a truck with GVWR under 26k, an air brake endorsement is not needed. Want proof? Penske, Budget, and Ryder will all rent you a box truck with air brakes without a CDL or air brake endorsements.
    Also, the cutoff is 26,001 lbs or more, so a truck that says 26,000 GVWR is technically not CDL. Despite that, most mfg's will rate at 25,500, 25,950, or 25,999 to avoid any confusion.
