Truck Number Placement, is there a regulation I need to follow?
Discussion in 'Ask An Owner Operator' started by T.Rucker, Sep 18, 2021.
  1. T.Rucker
    T.Rucker Medium Load Member
    414
    1,018
    Jul 31, 2015
    Here and there…
    I’m in the process of lettering my truck. Got the name, DOT number etc. My question is about the placement of the truck number. As in 01, or 23 etc. Is there a regulation that says where I need to place that? I can’t seem to find one. Most people I understand put them on the side of the hood, I was wondering if that’s a rule I have to follow.
    Any help is appreciated. Thanks
  3. God prefers Diesels
    4,198
    22,259
    Jun 26, 2020
    South Texas
    You don't have to display that number at all. The only things you have to display is company name, and USDOT number.
  4. MacLean
    MacLean Road Train Member
    1,266
    3,712
    Sep 12, 2017
    Unless if you haul into Canada then I believe it’s a requirement. I seen a guy getting yelled at for that (not having it) in New Brunswick one day.
    Rideandrepair and T.Rucker Thank this.
  5. God prefers Diesels
    4,198
    22,259
    Jun 26, 2020
    South Texas
    I'm also pretty sure you have to display VIN if you're based out of CO. But barring specific situations like that, 99.99% of the time, you just need company name and USDOT.
    Rideandrepair Thanks this.
  6. Rideandrepair
    17,209
    55,827
    Aug 8, 2015
    I thought a “unit” # was required. Along with Name and USDOT#. Nothing else.
    T.Rucker Thanks this.
  7. T.Rucker
    414
    1,018
    Jul 31, 2015
    Here and there…
    Thanks. I was thinking that, I just wanted to make sure. I’ve searched around and can’t find anything about having a visible truck number. I’m trying to keep lettering to a minimum lol
  8. T.Rucker
    414
    1,018
    Jul 31, 2015
    Here and there…
    I know it’s required for registration purposes, but I can’t find where it’s required to display on the truck…
    Bean Jr., Cat sdp and Rideandrepair Thank this.
  9. Rideandrepair
    17,209
    55,827
    Aug 8, 2015
    That’s probably where I got the idea. Sounds about right. Trailer doesn’t need a number. Probably same for Truck. I have the minimum, name, USDOT# and unit #. That’s all. I’ve heard “ fire extinguisher inside” is a requirement. Maybe. I’ve had them measure the size of my numbers in Ohio. They were 1/2” over minimum. I see some Big Megas with tiny Lettering. But Noooo, I get harassed.
  10. T.Rucker
    414
    1,018
    Jul 31, 2015
    Here and there…
    Haha yup….mine are 2” exactly…but I sure have seen many companies with much smaller lettering. They like to harass the little guys I guess. I’ll put the unit # on if I have to but for now I’m waiting till DOT says otherwise…
  11. Cat sdp
    Cat sdp . .
    20,819
    71,604
    Apr 8, 2012
    Orion's Belt
    The fire extinguisher thing is if you have it mounted in a box . You need that signage on the box…….
    If it’s mounted next to drivers seat you don’t need it
