Truck making Ticking noise when throttle-EXHAUST LEAK OR SOMETHING ELSE-VIDEO
Discussion in 'Trucks [ Eighteen Wheelers ]' started by DetroitSpecial, May 3, 2015.
  1. DetroitSpecial
    DetroitSpecial Light Load Member
    76
    31
    Mar 18, 2015
    So i have this leak,at least it sounds like a leak its making this ticking noise,i checked oil level,i checked hoses,& exhaust ,
    i dont know what da problem is,could it be i need a overhead adjustment?
    You can here the ticking better once the engine reving comes down,youll here it better listen close
    Heres the link to the video you may have to copy n paste in your browser to view it
    Link--> https://youtu.be/sho24biZvlQ
    If any Ops or Mechankcs can help me out on what it mite be or where else to look before it goes in the shop,would be appreciated
    The video link is here i posted it on youtube
    95 international
    12.7 Detroit 60 series
  3. little cat 500
    2,044
    1,090
    Jan 17, 2010
    Abbottstown PA
    bad injector maybe or maybe the cam is bad
    DetroitSpecial Thanks this.
  4. DetroitSpecial
    76
    31
    Mar 18, 2015
    Ok,thanks for your reply so you are saying that it Doesnt it sound like a exhaust leak? Right
  5. QUALITYTRUCK
    1,801
    1,762
    Jun 14, 2009
    romulus,mi
    sounds like a broken adjuster on a rocker. Valve cover going to have to come off.
  6. DetroitSpecial
    76
    31
    Mar 18, 2015
    That thought crossed my mind,thats why i was saying about a overhead adjustment,thanks for your thought
  7. Heavyd
    Heavyd Road Train Member
    7,749
    6,184
    Feb 4, 2009
    Something is broke up top. Take the cover off and have a look.
  8. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,727
    Jan 30, 2010
    keep stroking.
    look at the gasket area where the turbo bolts on. and the gaskets at each exhaust port for black soot. if none then it is under valve cover. if you had a broken rocker you would know it! had an engine in here a while back that had the same sound. ended up being a wrist pin bushing fell apart on a piston. but that was more of a knocking sound.
  9. DetroitSpecial
    76
    31
    Mar 18, 2015
    Ok i will do,either way im pulling the valve cover off to inspect it,i hope its nothing major
  10. Old Man
    Old Man Road Train Member
    4,597
    13,469
    Apr 3, 2009
    Oklahoma City, OK
    Check the center section of the exhaust manifold, they burn out.
  11. DetroitSpecial
    76
    31
    Mar 18, 2015
    So heres what we found,when you 1st crank the truck up and floor it no hesitation,but at the end of flooring it you look up at the exhaust pipe and a little white smoke comes at the end,so my mechanic checked the oil,he says that he can smell diesel in the oil,which isnt a good thing he says the diesel in my oil could eventually wear out my barons in my motor,he says that the noise probably is a bad injector either going out or about to go out so im pricing them to see who have the cheapest so far truck pro is the cheapest with core,but since ima be right there and have to change the valve cover gasket,im thinking bout pulling the head also and replace the head gasket,because i believe i see some kind of liquid i believe its coolant running along down the gasket,I believe im doing the right thing,by saving me more time and money in the long run,since i had this truck i havent changed nothing on it besides the air bag,and a tire.truck is not running hot but i try my best to stay on top of things before it goes Bad.
