Truck is pulling to the right not sure what the problem is...
Discussion in 'International Forum' started by HammerDownISX, May 4, 2014.
  1. HammerDownISX
    HammerDownISX Bobtail Member
    18
    4
    May 4, 2014
    Chicago IL
    Hey drivers I have a 2010 international prostar with about 440,000 mi on it front end is tight king pins are fine I recently got a 3 axle allingment and truck still pulls to the right I don't have any uneven tire wear does anyone have any idea what the problem can be?
  3. Cfifteen
    Cfifteen Bobtail Member
    40
    14
    Dec 5, 2013
    Vancouver, BC
    Check your U-joints on the steering shaft from the firewall to the gears. Just replaced the shaft itself (joints and shaft assembled) and I no longer have that same issue. It's kinda weird actually!
    Cheers,
    NCTru919 and Dr_Fandango44 Thank this.
  4. Preacher Man
    Preacher Man Road Train Member
    2,930
    2,776
    May 31, 2008
    Mason City, IL
    Are you sure you're not fighting wind? I've been having the same problem, then when the winds shifts, or I drive a different direction the problem goes away. I love it when the wind shifts just as I change direction. I end up fighting a headwind, or crosswind both directions.
  5. HammerDownISX
    18
    4
    May 4, 2014
    Chicago IL
    u joints are fine i get them greased and specifically look if that was done after every oil change
  6. HammerDownISX
    18
    4
    May 4, 2014
    Chicago IL
    i don't think that its the wind it happens constantly it will be eve worse when the wind hit me from the left i cant hold the wheel straight im constantly holding it to the left to compensate for the pull
  7. IH Truck Guy
    4,120
    46,700
    Mar 2, 2008
    Purgatory
    Swap your steer tires and see if it pulls the other way....
    CargoWahgo and HammerDownISX Thank this.
  8. HammerDownISX
    18
    4
    May 4, 2014
    Chicago IL
    i will definitely try that thanks
  9. snowwy
    snowwy Road Train Member
    20,527
    13,262
    Jul 6, 2009
    rotate your steer tires from left to right and right to left. if the truck now pulls to the opposide side. it's a tire issue.
    how bad is the pull??? if it's just a slight pull. that's normal. when roads are built. they are built with a crown. angled downward to the right so that water and snow run off. it's not uncommon for vehicles to pull to the right becuase of that. but it shouldn't be a extreme pull.
    i've had cars. with bad tires. that when you took your hands off the steering wheel. the car would turn around a light pole. on it's own.
    when mechanics do alignments most don'[t take that into consideration and just give it a standard alighment.
    when i did alignments back in the day. i would adjust the left side to pull slightly to compensate for the road crown.
  10. lovesthedrive
    lovesthedrive R.I.P.
    15,953
    54,483
    Nov 11, 2008
    Sorrento Maine
    Jack the front wheel up and spin it. One of them is out of round or you have a broken tread. Granted with broken tread you will also get a thump-thump-thump-thump as you drive.
    NCTru919 Thanks this.
