Truck goes into gear but doesn't move
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by BurjKhalifa, Nov 22, 2023.
  1. BurjKhalifa
    BurjKhalifa Bobtail Member
    20
    6
    Nov 22, 2023
    Hi, I'm having problems with a 96 Peterbilt , Super 10 transmission. Dump truck
    I went up a steep dirt hill, and after that I noticed that the transmission was jumping. After shifting from low to high ( 5-6, 7-8) it would jump and the rpms will stay the same.
    I would drive in 9th gear at 45 mph and the rpms will stay at around 1000 when normally it would go to 14-1500. at some point in 9th gear it marked it was at 60 mph and the rpms would be lagging.
    Anytime i would shift the rpms would stay really high.
    After I made it to my yard, I parked it and tried to move it again and it would not move. In Gear the driveshaft would not spin. However, it does go into all the gears. but releasing the clutch it would not move and it will stay in gear. Starting it gear it did not move either. Would i need to replace the transmission or is it something simple?
    Thanks
  3. nomud
    nomud Bobtail Member
    Jan 23, 2020
    Time for a new clutch
    Magoo1968 and Oxbow Thank this.
  4. BurjKhalifa
    20
    6
    Nov 22, 2023
    clutch is only 1.5 years old. maybe 15k miles max
  5. Last Call
    Last Call Road Train Member
    7,568
    45,898
    Mar 15, 2021
    If your lucky it might just need adjusted
    But I’am with @nomud you probably need a clutch
    Oxbow Thanks this.
  6. 201
    201 Road Train Member
    12,047
    24,587
    Apr 16, 2014
    high plains colorado
    Listen to this. Once a Mack quad axle for an asphalt company I worked for, the driver stopped on a scale, got his ticket, got back in the truck, put it in gear, wouldn't move. Turns out, the crankshaft broke right before the flywheel. I don't think that's what happened here, and we can speculate all day, but it needs to come apart, sorry. If your old clutch discs have springs, get the extreme duty ones without springs.
  7. Ban1
    Ban1 Bobtail Member
    40
    182
    Nov 22, 2023
    Doesn’t matter if you’ve burnt it up. Which sounds like what’s happened.
    W923, Bean Jr., Gridaxe5588 and 3 others Thank this.
  8. little cat 500
    2,044
    1,090
    Jan 17, 2010
    Abbottstown PA
  9. BurjKhalifa
    20
    6
    Nov 22, 2023
    replace transmission n it worked. Clutch was fine
    JB7 Thanks this.
  10. xsetra
    xsetra Road Train Member
    5,094
    6,940
    Aug 21, 2011
    I would have replaced the clutch and all the working parts along with having the flywheel turned, while the transmission was out.
