Truck Advice -Log Trucks
Discussion in 'Questions From New Drivers' started by DirtyBrown, Dec 1, 2015.
  1. DirtyBrown
    DirtyBrown Bobtail Member
    48
    14
    Dec 1, 2015
    Middle Georgia
    Good afternoon fellas,
    My dad has been driving for many years hauling rock for a company, recently we've been throwing around the idea of getting a day cab and hauling logs for a company who has been after him for quiet some time. Everybody locally has been recommending a Freightliner Columbia with a Detroit motor. I was wanting to know if there were any pros and cons I should be aware of and if anybody has a better suggestion as far as trucks go?
    Thanks in advance guys,
    Derek
  3. crzyjarmans
    crzyjarmans Road Train Member
    3,310
    2,427
    Jun 9, 2010
    Home
    Lots of variables on this question, looking for used? Or new? If new, freightshakers don't hold their value as well as a kenworth or Pete, if your looking for used? You may be able to find a fairly decent freightshaker, also what type of weight are you going to be hauling? You will need to make sure the truck you buy is spec'd out to what your going to be doing, best of luck
    DirtyBrown Thanks this.
  4. DirtyBrown
    48
    14
    Dec 1, 2015
    Middle Georgia
    The Truck and trailer will typically be hauling mid 80s, we get fined down here for over 88K, I also was interested in a Pete but i hear a lot of complaints about their electrical systems. Another reason for avoiding the Pete and Kenworth is due to the Caterpillars being so common and expensive to work on...I've heard the detroits were pretty good motors and had more availability in parts than others
  5. sliver
    sliver Light Load Member
    230
    242
    Feb 17, 2015
    idaho
    If your dead set on a detroit buy western star. IMO frieghtliners arent built for the woods. Kw pete mack and western star are way better trucks and will hold up better in vocational use like logging and construction. Just my personal opinion. 6nz cat will run forever great motors but detroit is cheaper to overhaul. In the northwest where im from logging is big and I can maybe think of a handfull of guys running frieghtliners
    scottlav46, AModelCat and DirtyBrown Thank this.
  6. DirtyBrown
    48
    14
    Dec 1, 2015
    Middle Georgia
    Are the cummins N14 a reliable motor? I have a guy locally who has a 99 Pete 379 with that motor that has been recently overhauled in the last 100K miles. He wants 18K for the truck, has been used to haul a dump wagon, any advice or suggestions on what to look for on that?
  7. AModelCat
    154,488
    There's a few guys running some heavy spec Coronado's in logging and light oil patch work around here. Never looked too closely at one though so I can't say how well they hold up. Personally I'd stick with either KW or Western Star. Heavy spec'd with 46k rears, full lockers, 4:10 or 4:33 axle ratio, 18 speed and 3/8" frame. Ground clearance is king in the bush so keep that in mind too.
    sliver Thanks this.
  8. sliver
    230
    242
    Feb 17, 2015
    idaho
    Dont have any persoal experience with N14 but I imagine its as reliable as a detroit. Life in the woods is tough on a truck. Ran a lot of western stars for a guy I worked for all had detroits except last one had the signature 600 cummins it was a great motor loved that truck . Went to work for owner op with just 2 trucks bought the truck I was driving from him 378 pete 6nz cat 46 rears 18spd alpine rigging was a great truck hauled logs everyday in some awfully harsh Conditions no real problems it just went to work.
  9. scottlav46
    scottlav46 Road Train Member
    1,007
    6,430
    Jun 18, 2015
    Escanaba, MI
    My main question would be: are you goin down woods roads to pick up product? We do a lot of heavy logging up here, both double bottom self loaders and 5-7 bunk crib trailers. In our experience the freight shaker is an awesome highway truck but not so much in the woods. Of course if you're only haulin in the neighborhood of 80k you might make out ok. If the trucks gonna take a beatin and you need it to put food on your table I'd seriously consider a heavier spec'd truck. Just my two cents. Good luck with the new endeavor!
    sliver Thanks this.
  10. Jubal3
    Jubal3 Heavy Load Member
    878
    950
    Apr 2, 2015
    Central WA
    Just got done doing a short stint as a logging truck driver. KW- Forget it. Those Paccar motors will NOT work for you.
    PM me and I will give you contact info for the company I was working for, whi will be happy to share out their specs. I know we were running PETE 579s with Oversize drive tires and Cummins motors. Best running truck I've ever driven. Runs 6% grades fully loaded at 65 MPH.
  11. KMac
    KMac Road Train Member
    3,427
    3,065
    Jan 26, 2012
    Waxahachie, TX
    Anyone else see the headline and thought it had to do with Logbooks? LOL
