I've got a Freightliner with a Thermoking TriPac. I understand and use the air conditioning with no complaints. The heat either barely works or I'm not using it correctly. Here's wjat I do:
1 press & hold the on/off knob
2 rotate A/C, Fan, Heat knob to heat
3 rotate temp knob fully clockwise into red zone
4 wait
The APU kicks on, air starts coming from vents. Many minutes later the air is barely at room temp, if that. I haven't had real cold yet so I havent taken time to read through the manual. The heat on the dash works great. I never have to wonder "is that warm? Is it working?"
I have an Espar (sp?) heater control. It heats up quickly. Should I just use the APU for A/C & Espar for heat. I can live with that.
TriPac APU & Sleeper Heat?
Discussion in 'Experienced Truckers' Advice' started by tscottme, Nov 23, 2017.
Page 1 of 4
So if you have a bunk heater that works well, what is the problem exactly?
Use your tools as they work best. -
I have a similar set up. Mine is all controlled through the TK controller, but mine is digital, no dial. I put it on HEAT, and that's it. It has a separate opening for the heat, than the AC ports. And it will roast you. I set it on 62 lol.
My APU will click on maybe 2 or 3 times during the night, and I've no clue why. I need to call TK and ask them how to make it run all night, cause it is plumbed to the engine and would serve as a block heater.tscottme Thanks this. -
In heating mode a TriPac engine only runs when it needs to charge the batteries, or if programmed to warm the engine coolant. By not running it saves more fuel.
Justrucking2 and tscottme Thank this. -
stwik, 86scotty, tscottme and 1 other person Thank this.
Yes in heat mode the APU does nothing more than charge batteries. The heater is a gas heater, taking fuel from the diesel tanks. There is a flame inside that thing all the time. There is very little draw in heat mode, only the little fan is actually drawing DC current. Maybe the little igniter thing to keep the fuel burning, but still, not much.
Phoenix Heavy Haul, Justrucking2, ChicagoJohn and 2 others Thank this.
I wasn't sure if running the Tripac long enough would cause it to eventually start providing normal heat to the sleeper. You won't believe this, but some training programs don't spend any time going over such details. It's like all they think important is moving the freight and never think about living in the truck.x1Heavy Thanks this. -
Dave_in_AZ Thanks this.
Page 1 of 4
