i have a 05 pete tri axle dump with a c-15 acert 475 1850 tq mxs there was a guy at a shop 8 miles away supposed to be a wizard lol so had him do a tune up he did over head and changed trim codes and then said i would gain 100+ hp i doubted it but didn't say anything well lost power and .5 mpg and idles rough so next day called him he came few day's later checked over head made little adj so today same thing so called him today asked him to put original trim codes back in he don't have them and said that's not my problem with the truck running rough i say it is what do you think? and can i see the trim codes if i pull the valve covers? thanks![]()
trim code?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by 05379, Sep 30, 2011.
Yes if you pull the covers you can get the trim file number and confermation code then you will have to find a shop with cat ET and the trim file disk and give them the numbers and there corresponding cylinders.
The trim numbers are on the injector itself pull the valve cover and get the 4 digit number off each solenoid.
there is 2 #s 3504 on all injectors then all others are dif example 0632d9e so those seem like what i need ?
No they are on the top of the injectors where the injector rocker pushes on the injector itself. Some times they can be hard to see
The numbers are on the side of the injector solenoids. You're going to have to take the truck to a CAT dealer. He'll have to pull the valve covers to read these file numbers. The number is actually a reference to a Injector Calibration File. The dealer will then have to download the correct Injector Calibration File from CAT for each injector in the engine and then load it into the ECM.
Did he flash the ECM with a 625 Hp file? This usually causes a lose in power and poor fuel mileage in a 550 engine.
