Tricks to throwing straps on tall loads and saving your wrists?
Discussion in 'Experienced Truckers' Advice' started by TooTiredToTalk, Apr 18, 2022.
  1. TooTiredToTalk
    TooTiredToTalk Medium Load Member
    636
    2,935
    Feb 24, 2022
    Hey y'all :)
    Hope the day has been wonderful for all of my fellow drivers! I just wanted to get some advice on how to throw straps better over tall loads because my wrists are killing me now. Also what is an easier, more efficient way to fold the excess strap.
  3. Chinatown
    Chinatown Road Train Member
    73,251
    164,503
    Aug 28, 2011
    Henderson, NV & Orient
    Some tie a light rope to the strap, then throw the light rope over the load. Then go to the other side and start pulling.
    I didn't do it that way though; I'd stand with my back to the load, then with both hands, throw the coiled strap over my head and back over the load.
    If you do it this way, secure the bitter end of the strap to the trailer first.
  4. bad-luck
    bad-luck Road Train Member
    3,245
    5,944
    Nov 16, 2013
    Baltimore, Maryland
    Been a while since I pulled a flatbed, but I used to roll it up and throw it over like baseball.
  5. PSM379
    PSM379 Heavy Load Member
    893
    3,556
    Apr 19, 2019
    B0A9F14A-B3D4-4F61-B348-13D238165C96.png I take my straps off winches after every is. Roll them up with the hook out. Then when I need to throw again I can hook the hook, take the rolled up strap then throw it over. I fold my straps up, then slide it thru winch and keep excess like this. Also tightens better in my opinion. I’m sure someone can explain better
    TooTiredToTalk, roshea, CAXPT and 3 others Thank this.
  6. BigBob410
    BigBob410 Road Train Member
    5,665
    74,100
    Feb 2, 2016
    Beirut on the Bay, MD.
    That’s what I was going to say. After watching many folks dinging their wheels throwing the hook and having been hit by a flying hook or 3 I changed to throwing the strap and it seems to save an extra trip around the trailer
  7. rockeee
    rockeee Medium Load Member
    338
    653
    Apr 22, 2015
    Kalama, Wa
    This. Except never secured the J hook first. Strap your load and don't crank it down completely. For taking care of the excess for the most part I have always rolled it up so it you lay the rolled part flat, it would be 8 to 12 inches and slip it under the strap that is securing the load, then tighten it down all the way. Lots of You Tube videos. Some loads you might not be able to do it this way so you will have to be inventive
    TooTiredToTalk, Vampire and Chinatown Thank this.
  8. GYPSY65
    GYPSY65 Road Train Member
    1,956
    5,263
    Nov 16, 2012
    SW FLA
    Ok
    I’ll try this without video
    I roll my straps tail side in and words on strap inside the roll
    That way I can hook them and when I throw them they Unroll correctly
    I hook the strap to the trailer. Walk back 15’ or so while unrolling it. Far enough to clear the load once I throw it
    Then I take the roll. Walk forward some and make a loop and a sling
    Once you have the sling and it’s pinched against the roll you have a lot more throwing power
    I searched for a video but couldn’t find one so I took a couple pics. Imaging the strap is hooked to the trailer
    Once over. I fold the strap and put it through the winch and push it through the other side with a flat thin piece of aluminum as dot would want to see it through both slots if they inspect it
  9. supersnackbar
    18,596
    44,699
    Aug 19, 2007
    Your Town, USA
    Same technique, different YouTubers
  10. GYPSY65
    1,956
    5,263
    Nov 16, 2012
    SW FLA
    I sorta do that only difference is I pinch the roll and use it like a tight sling??
  11. mitmaks
    mitmaks Road Train Member
    2,542
    2,064
    May 16, 2014
    I usually attach D ring to hook and then make sure I have lots of slack and throw it over. You can use 2 hands to build up more momentum. Before Id try holding hook/Dring in my left and and throw with right hand and that didn't work well.
    TooTiredToTalk and Chinatown Thank this.
