Tri Pac apu belt
Discussion in 'Trucks [ Eighteen Wheelers ]' started by mitmaks, Jan 28, 2018.
  1. mitmaks
    mitmaks Road Train Member
    2,542
    2,064
    May 16, 2014
    Why did they make installing belt so hard on these units? Have to have 2 people, one pushing on alternator while another is tightening bolt.
    I've lost a new belt cause Thermo king employee didn't tighten it down right enough.
  3. lilillill
    lilillill Sarcasm... it's not just for breakfast
    5,642
    13,470
    Nov 7, 2007
    Possum Booger, Alabama
    Yours doesn’t have a turnbuckle?
  4. mitmaks
    2,542
    2,064
    May 16, 2014
    No there's no turnbuckle. So you can only tighten belt as hard as you can push on alternator to put tension on the belt.
  5. lilillill
    5,642
    13,470
    Nov 7, 2007
    mitmaks Thanks this.
  6. fargonaz
    fargonaz Road Train Member
    1,167
    4,583
    Feb 9, 2015
    Mesa, AZ
    With a good belt, it shouldn't take much tension(gates K060478 good replacement, can get at any auto parts store) just basically taking up the slack. I use a big flat box wrench between the alt and the engine casting(barely fits, so I don't have to move it far). Is your APU going to standby when you start the truck? My standby wire got pulled off the ignition switch accidentally and nothing lasts long while the APU is running with the truck going down the road.
    Just some thoughts.
    PS: thanks for the fuel filter video!
  7. mitmaks
    2,542
    2,064
    May 16, 2014
    I stopped at petro and got Gates replacement belt and it seems to be bigger. It started squeaking when there's load on alternator.
    I've got factory Tri pac belt on order
    How's that tool supposed to work? Never seen anything like it, looks like harp from medieval ages.
  8. lilillill
    5,642
    13,470
    Nov 7, 2007
    Go a few milimeters smaller on the belt size then. For example, K060475.
    The tool wraps around and hooks into the alternator so you can apply pressure with a 1/2” drive ratchet.
  9. BrandonCDLdriver
    BrandonCDLdriver Road Train Member
    1,191
    1,462
    Sep 1, 2017
    I have a tripac on my truck and I had an issue with it and the mechanic replaced the belt by himself so it can be done.
    PE_T Thanks this.
  10. mitmaks
    2,542
    2,064
    May 16, 2014
    How do I remove lower side cover where muffler attaches to. Do I have to remove muffler to get it off?
  11. lilillill
    5,642
    13,470
    Nov 7, 2007
    You just have to remove the two bolts off the muffler bracket and let it hang. Then there are four bolts on the cover and possibly nuts on the inside, if the captive nuts have twisted off like mine have.
