tri-axle usage
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by uhjohnson, Oct 8, 2014.
  1. uhjohnson
    uhjohnson Bobtail Member
    43
    Jun 13, 2014
    when should a.third axle be raised with a load and not on the highway and when should it be raised on the highway
    thanks
  3. Agtrucker
    Agtrucker Light Load Member
    152
    43
    Dec 14, 2011
    Is this a statement or a question?
  4. Cat sdp
    Cat sdp . .
    20,819
    71,604
    Apr 8, 2012
    Orion's Belt
    Around here tri-axle up(even around a sharp corner) with a load means no overwieght permit= big overwieght ticket.
    I've dragged one around a lot of corners... Just take it easy. In a customer parking lot... Pick it up.
    uhjohnson Thanks this.
  5. uhjohnson
    43
    Jun 13, 2014
    What can be damaged and how does it happen
  6. JPenn
    JPenn Road Train Member
    1,829
    1,873
    Mar 5, 2008
    Northern Tier PA
    Can pop tires if it's a non-steerable axle and you're heavy or turning too fast. We use straight trucks here with 2 or 3 drops (all steerable) and typically pick up the tag (behind the drive axles) in tight or off-camber turns. Haven't gotten an overweight in either NY/PA or OH for doing so, though I am sure the possibility exists. Mostly our difficult turns are far enough off the beaten path that you don't come across many LEO's looking for quotas though.
  7. uhjohnson
    43
    Jun 13, 2014
    So if you get caught lifting your axle with a load on the highway to make a turn easier and safer and the LEO sees the infraction will he ticket you for being overweight
  8. Cat sdp
    Cat sdp . .
    20,819
    71,604
    Apr 8, 2012
    Orion's Belt
    Some states will..... In NY is illegal to have a switch to lift the axle " within the reach of the driver". And a lift axle has to be steerable on new trucks/trailers. But a non lift tri- axle doesn't ..... Go figure !
  9. JPenn
    1,829
    1,873
    Mar 5, 2008
    Northern Tier PA
    NY's dumb like that. Don't see 'em giving the dump trucks or tanker straight trucks trouble. There are tons of them running around with non-steerable lifts, and in order to turn a corner, they have to lift. Hard to manage that with an unreachable switch.
    mpd240 Thanks this.
  10. lobes1985
    lobes1985 Medium Load Member
    306
    112
    Aug 9, 2009
    Wappingers Falls, NY
    This isn't entirely correct. You can have the switch in the cab to lift the axle. Its the valve to adjust the air pressure in the lift axle that has to be outside the cab. Anything 2005 and newer in NY has to be a steerable. They were going to require all trucks and trailers with lift axles to be steerable by the expiration of your overweight permit in 2015. They have extended that deadline to 2020.
    Cat sdp Thanks this.
  11. Cat sdp
    Cat sdp . .
    20,819
    71,604
    Apr 8, 2012
    Orion's Belt
    Is the part about a solid tri-axle on a trailer correct ?
