Tri-axle dump truck weight?
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by Dino soar, Jan 24, 2025.
  1. Dino soar
    Dino soar Road Train Member
    4,789
    26,858
    Dec 8, 2017
    I was wondering which manufacturer made the lightest tri-axle dump truck between 1985 and 2003?
    Does anyone have one that they know the lightweight?
    The Mack is really a great heavy duty truck, but they're heavier. When you're hauling by the ton, the lightness of the truck really makes a difference.
  3. 201
    201 Road Train Member
    12,044
    24,581
    Apr 16, 2014
    high plains colorado
    I believe FL is the lightest truck. Used to be the Louisville Ford, but good luck with that. Mack was the heaviest, and don't forget the trailer. Frameless aluminum saves weight, and big fuel tanks too. You're right, it adds up.
  4. Dino soar
    4,789
    26,858
    Dec 8, 2017
    I have a Freightliner tractor and I would prefer to buy a Freightliner tri-axle dump truck, if I buy one.
    The old Ford dump trucks actually were not bad trucks but believe it or not there are parts in those trucks that are crazy expensive.
    But some of those Ford tri-axles had real heavy single frames.
    I would think twice if I found one of them.
    I would be happy to avoid a double frame if it was possible, because every one of them eventually turns to junk.
    201 Thanks this.
  5. Oxbow
    Oxbow Road Train Member
    12,448
    127,833
    Nov 24, 2015
    My 2000 W900B with a 6NZ set at 475, 14600 front running 315s, 46k rears running 11R 24.5s, Chalmers suspension, 18 spd, and Reliance transfer box weighs 25600. It was purpose built as a dump truck and pulled a 4 axle transfer box before I purchased it.
    Tug Toy, Dino soar and motocross25 Thank this.
  6. AModelCat
    154,242
    I'm with you on the double frame. IMO they aren't needed as often as people think they are. My thoughts are if you need a heavier frame, spec it with a heavy single rail.
    PSM379, Dino soar and Oxbow Thank this.
  7. Oxbow
    12,448
    127,833
    Nov 24, 2015
    Rust jacking wasn't that big of an issue 20 years ago in the west, but it dang sure is now.
  8. AModelCat
    154,242
    I really can't say I've seen many trucks with double frames. Years ago I worked for a vac truck outfit and I don't think any of their trucks were running double frames even with 20k steers and 69k rears.
    Oxbow Thanks this.
  9. Dino soar
    4,789
    26,858
    Dec 8, 2017
    Here in the Northeast where I'm at, we get a full change of seasons. We can literally go from 90° in the summertime down to 10° or something like that in the winter on average.
    I think the weather really messes with those double frames.
    Sometimes there's no rhyme or reason.
    I've seen 40-year-old trucks with frames that looked virtually brand new and tight, and I've seen 15-year-old trucks with junk frames.
    Nowadays the newer Tri axles here are being fitted with heavy single frames.
    And colossal expensive emission engines...
    If you do any framework, PG Adams up in Vermont will sell you frame rails to replace the double, with a really heavy single frame that has the right strength.
    Not looking to do any jobs like that right now, though.
    Don't know what it cost now to have the frames done, but probably 10 or 15 years ago it was $30,000.
  10. Dino soar
    4,789
    26,858
    Dec 8, 2017
    201 Thanks this.
