Tri-Axle Drive Heavy-Haul Tractors
Discussion in 'Heavy Haul Trucking Forum' started by ROBERTCADAMS, Mar 20, 2014.
  1. ROBERTCADAMS
    ROBERTCADAMS Light Load Member
    51
    63
    Sep 23, 2013
    Crossville,TN
    Hello,
    If anyone on this Forum is currently using a Tri-Axle Drive Semi Tractor for Heavy-Haul and you dont mind answering some questions,PLEASE send me your e-mail address to robertcadams1963@aol.com .I have a few questions and need to ask someone who is using this type of set-up.Thank you in advance for your time.
    Robert
  3. Ruthless
    Ruthless Road Train Member
    8,784
    85,934
    Aug 28, 2010
    The City.
    Ask them out here in the open- gives info for folks in the future with the same questions ;)
    MJ1657, Cetane+ and toostroked Thank this.
  4. 281ric
    281ric Road Train Member
    1,248
    809
    Oct 20, 2011
    TX
    I was thinking the same thing. Ill try to ask a lot in public here instead of pm for educational & entertainment purposes.
    MJ1657 Thanks this.
  5. dude6710
    dude6710 Road Train Member
    2,162
    622
    Mar 26, 2010
    MN
    I was thinking who uses aol still?
    Cetane+ Thanks this.
  6. passingthru69
    Wait for Haulhand to reply, He had one before.
    I got a buddy who just bought one for all the wrong reasons. To me they are not really worth the extra hassles unless you have a steady contract that will benfit having a tri drive. Extra weight/ costs with maintance. Hard turning..
    Like I stated wait for Haulhand to reply
  7. leftlanetruckin
    leftlanetruckin Road Train Member
    3,607
    3,160
    Mar 12, 2009
    Mo Via Blackpool,Lancs.
    When I had mine......This is exactly what I thought too.
    I saw no advantage to it myself, besides traction with the full lockers engaged. Think it's an advantage in Canada in places, but never took mine there to find out. If I was to ever go 4 axle truck again, it would be a lift.
    Not sure exactly what you want to know, so maybe post up the specifics.
    Martin
  8. haulhand
    haulhand Road Train Member
    Really the only advantage is extra traction. We used ours off road in the mud and ice every wintry and could get places nobody else could but they are heavier than a 4 axle with a lift and as Carl stated hard to turn in slick conditions. The only place I've ever found where there was a weight advantage is in Alberta and Saskatchewan as they don't recognize a lift. I don't kno what your wanting to use one for but unless your wanting a truck that will eat up crappy conditions with a heavy load go for a lift axle.
  9. UltraZero
    UltraZero Medium Load Member
    406
    96
    Jul 18, 2013
    Hi all. Re 4 axle trucks, are the lift axles a dead axle or live?? New to this topic.
    Thanks
    Oh. What about places like Michigan where weight limits are much higher.
    Thanks
  10. haulhand
    Lift axles are dead. And some that don't lift are dead as well like Carls freightshaker.
  11. passingthru69
    Yep, mine is a dead axle. The only way it lifts is dumping the air and chain the axle up.
    I got it changed up now as the last ld. and then the ld. I'm getting this week is a light ld. also.
