Trestle jack review
Discussion in 'Ask An Owner Operator' started by feldsforever, Sep 26, 2021.
  1. feldsforever
    feldsforever Road Train Member
    1,453
    1,440
    Nov 22, 2019
    I think thats what its called, has any one used one.?
    If your reading this and have not used it. Cording to youtube, its a jack you place horizontal. In position under where you want to lift the big truck. And it has a round ish bottom that flatens out. With it in place you pull forward or back up Untill it locks on the flat part to the ground.
    Any personal experiences would be great thanks.
  3. Big Road Skateboard
    5,687
    29,608
    May 2, 2021
    So it "cams" up? No real jacking needed?
    feldsforever Thanks this.
  4. Ridgeline
    22,103
    113,210
    Yes but as we found out with the pair I bought, nothing stops the truck from rolling beyond the point that it falls.
    feldsforever and skallagrime Thank this.
  5. skallagrime
    skallagrime Road Train Member
    3,836
    9,879
    Apr 10, 2012
    Indiana
    So, useful for steer axle, or trailer, and requires 2 or 4, doesnt look any lighter or smaller than jack stands or a bottle jack (larger than a single in fact) and height has a relatively low limit as well due to how the cam seems to work.
    Good application of physics, a+
    Poor real world wide use case d-
    feldsforever, baha and RedForeman Thank this.
  6. feldsforever
    1,453
    1,440
    Nov 22, 2019
    Ok. I won't be getting them, thank you again every one.
  7. Ridgeline
    22,103
    113,210
    It is great for a shop setting where you can have stops set up to stop the truck. Even using wheel chocks to stop the truck didn’t prevent the chock from moving out of place.
  8. feldsforever
    1,453
    1,440
    Nov 22, 2019
    Stops as in wall or something similar?
  9. ProfessionalNoticer
    2,941
    7,852
    Apr 25, 2021
    If you're looking for something to keep in the truck with you or for more portability try Harbor Freight's bottle jacks. I have a couple and they work well at an affordable price. Grab some HD jack stands too.
  10. feldsforever
    1,453
    1,440
    Nov 22, 2019
    I have a dirt drive way at home. With limited space. I will look into the harbor Frieght ones next thank you.
  11. skallagrime
    3,836
    9,879
    Apr 10, 2012
    Indiana
    Because your drive is dirt, you will need to have a proper base under your jack/stands, consider pouring a concrete pad or large blocks of wood.
    See picture.
    Speed_Drums Thanks this.
