Transporting 500 gallon fuel tanks
Discussion in 'Hazmat Trucking Forum' started by Gasboy2006, Jun 23, 2019.
  1. Gasboy2006
    Gasboy2006 Bobtail Member
    My company wants me to transport 500 gallon skid tanks to and from job sites on a flatbed under 26000 lbs, some of these tanks are diesel and some are gasoline. there will be residue to several gallons of fuel in them
    Question: Am I required to have a CDL with hazmat to do this?
  3. dclerici1
    dclerici1 Medium Load Member
    525
    1,582
    Aug 1, 2012
    MISSOURI
    Are the tanks themselves placarded?
  4. RustyBolt
    RustyBolt Road Train Member
    2,073
    3,333
    Feb 21, 2015
    Bement, IL
    Good question. Under 26k doesn't require it. But that hazmat (or not) puts a different spin on things.
  5. D.Tibbitt
    140,843
    I always thought the rule was anything under 1000 pounds didnt require placards. Anything 1001 pounds or more it had to be pacarded. I have never hauled hazmat so i have no idea if this is true or not
  6. ZVar
    ZVar Road Train Member
    10,911
    23,825
    Sep 10, 2010
    Flint, MI
    For the most part yes. Some exemptions are out there though. Like I know full sized fuel trucks have to be placarded even empty. Thats because of the fumes, they can still explode.
    It requires a washout ticket to run without placards.
    I just dont know if that's all tanks, or over a specific size.
    My suggestion for the op is to call or stop at a scale house and ask.
    D.Tibbitt Thanks this.
  7. kemosabi49
    10,435
    44,384
    Jan 13, 2013
    SW Arkansas
    If the tanks have residue then placarding is required, particularly if there is still fuel in them .If placarded, the driver must have the hazmat endorsement.
    If you have the tanks cleaned and a certification of such you are good to go.
  8. mud23609
    mud23609 Medium Load Member
    652
    1,444
    Mar 9, 2015
    The tanks are over 119 gallons thus they require placards and you would need a hazmat endorsement.
    Bwbibb and D.Tibbitt Thank this.
  9. Pedigreed Bulldog
    7,737
    14,421
    May 7, 2011
    ...and don't forget the tanker endorsement, too, if you're hauling more than 1 of them and they aren't empty. 119 gallon individual capacity and 1000 gallon total capacity triggers the requirement...so a single tank you'd be fine without...but add a 2nd or 3rd and you'd better have the tank endorsement. If the tanks are empty (or just residual contents), you'd be OK without the endorsement...but partially filled and you'll need it.
  10. 4wayflashers
    4wayflashers Road Train Member
    1,063
    1,230
    Mar 14, 2014
    They are HazMat until washed out. Must be placarded. Must have HazMat endorsement.
    Bwbibb Thanks this.
  11. wis bang
    wis bang Road Train Member
    3,348
    3,917
    Jan 12, 2011
    Levittown, PA
    Yup...Haz Mat and Tank required.....
