Transmission Whine noise (RTLO 16713A)
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by istumped, Oct 24, 2023.
  1. istumped
    istumped Medium Load Member
    493
    233
    Feb 8, 2015
    Eaton 13sp. Got a whine(noise)( very faint,can barely here it)in transmission(I think). Oil level good color,good. Can this trans be rebuilt on the truck( from the back) or does it have to be totally remove from truck. Never did trans work. How hard is it remove from truck. What is estimated removal time? Freightliner cascadia i can do engine overhead work,adjust Jake's,injectors, etc,etc in my sleep. Never messed with transmissions
    blairandgretchen Thanks this.
  3. MAMservices
    MAMservices Medium Load Member
    446
    2,945
    Aug 9, 2021
    Some slight whine can be completely normal. Check magnetic plug and see if there’s any metal of sorts other than just wear metal in it. Transmission cannot be rebuilt in the truck it must be removed. Back box can be removed and repaired while transmission is still in truck. Pretty good job to R&R a unit for a folks first initiation to transmission work. I came to like doing it and jumped at chances to do bench jobs. When I used to be worth something. Used to pay 9 hours to replace a clutch in FLDs and such. Be a good idea to check for metal and make certain the correct oil, (50 wt synthetic), is installed.
  4. Star Rider
    Star Rider Road Train Member
    1,307
    10,478
    Sep 23, 2019
    If you get into that back box you better know what you are doing. Those gears need to be timed.
  5. blairandgretchen
    13,216
    70,223
    Dec 9, 2011
    South west Missouri
    I'd take it to a good transmission guy and have it removed and gone through. Like said - check for metal fragments at the plugs first - or sample oil at a lab.
    Re man transmissions are assembly line, tolerance replaced temporary fixes.
    I have limited mechanical skills, but enough IQ to know it's not a task I would engage and learn on the fly if it was my sole income generator.
    Rubber duck kw Thanks this.
  6. Big Road Skateboard
    5,687
    29,609
    May 2, 2021
    Whines can travel the driveline. Noise originating further back can come up the driveline, up the stick, and you assume trans issues.
    You can't rebuild the trans from the back. You can rebuild SOME aux sections, but not all. Metric Fullers for example, the range fork is driven from the top plate of the main box, into the aux section.
    The top plate has to be removed to remove the aux section. So pretty much not serviceable in truck.
    Your RTLO, yes, you can remove the rear section. Is this truck new to you, or do you have quite a few miles on it?
    Have you verified correct driveline angle?
    OLDSKOOLERnWV Thanks this.
  7. istumped
    493
    233
    Feb 8, 2015
    Bought truck new. I know every noise it makes. I agree a noise can happen in the driveline And move up. However their has to be something internally because between 5&6 gear I have to wait a little longer to shift misses a gear. Like it's not building enough pressure(o ring). If their was a whine in the power divider it would have let go major catastrophic. Prior experience on previous truck.. Their are no good transmission shops where I'm at 1hr south of Chicago. If you know of one let me know. This is a emergency job.
  8. OLDSKOOLERnWV
    17,806
    268,403
    Whine in all gears or just in OD? How many miles on the truck…?
  9. istumped
    493
    233
    Feb 8, 2015
  10. OLDSKOOLERnWV
    17,806
    268,403
    You may have multiple problems that have slowly come to light.
    You turned the driveshaft and felt if it’s smooth or has resistance….?
  11. istumped
    493
    233
    Feb 8, 2015
    Smooth,typical gear slap with the miles that are on it in my opinion
