Transmission oil cooler lines bypass question - shady or legit?
Discussion in 'Freightliner Forum' started by PermanentTourist, May 6, 2021.
  1. PermanentTourist
    PermanentTourist Heavy Load Member
    749
    879
    Nov 9, 2016
    48 states + Canada
    So, I just got my 10 speed replaced with an in-house rebuilt unit at a little transmission shop in Fontana California.
    Apparently my old one went bad because I lost fluid because my cooler lines are bad.
    They could not get a hold of replacement cooler lines, apparently they are back ordered for a week or something.
    So they did something that's potentially fishy: plugged and bypassed the cooler lines.
    They are telling me:
    -That I don't really need them immediately because 10-speeds don't run hot.
    -That they bypassed them internally in the transmission so the pump will still circulate.
    - But somehow they did it in such a way that I can just put the lines back on and it will flow through the lines automatically without needing to take the transmission apart.
    - I don't need to be in a huge hurry to plug them back in, because all that's going to happen is my gear fluid will last half as long as it would otherwise, so like a year instead of two.
    All of this seems odd. I'm somewhat inclined to trust them because they do have a one year warranty and I doubt they would make something that would immediately destroy my transmission just so they have to redo it for free...
    But it's still odd to me that a transmission can just run internally like that without overheating as they are alleging.
    What are your thoughts? Is this a normal procedure or are they BSing me? Can I run this thing until I find time later in the summer to take the lines off of my old truck and put them on myself?
  3. Magoo1968
    Magoo1968 Road Train Member
    2,017
    5,395
    Mar 18, 2021
    St Malo mb
    They just ran a hose from inlet to outlet on outside of transmission. I needed to do that before it was fine except on 100 k loads the temperature rose a bit higher than I liked but was still in safe zone. I had to wait 4 weeks to get lines on mine .
    PermanentTourist Thanks this.
  4. PermanentTourist
    749
    879
    Nov 9, 2016
    48 states + Canada
    Okay, good to know.
    The good news for me is that I don't have no 100 K loads, just normal stuff. Heck, I don't even like taking anything over 30,000 pounds, it's just annoying to drive heavy stuff.
    The bad news is I don't have any kind of a transmission fluid temp gauge or anything like that. So all I've got to rely on is faith and trying to smell a weird smell if it starts overheating.
    Oh, one more weird thing. They did not run an outside hose, they just plugged it with metal screw in plugs. Apparently whatever they did is internal that they do on all their rebuilt transmissions. At least according to them.
  5. 062
    062 Road Train Member
    6,142
    33,155
    Oct 20, 2013
    Any hydraulic shop should be able to make the lines. If they already thrashed them call a dealer with the vin and they should be able to give you the specs to have them made.
  6. AModelCat
    154,264
    If it ran low how did you not notice a leak? It holds like 4 gallons of oil.
    You should be able to get those lines built at a hose supplier. Probably cheaper too.
    Bypassing the cooler is usually ok as long as you aren't working it hard. Most coolers are just a heat exchanger with engine coolant anyways.
    Magoo1968, Brettj3876 and rachi Thank this.
  7. DUNE-T
    DUNE-T Road Train Member
    6,876
    16,597
    May 10, 2015
    Detroit, MI
    Completely legit. I removed oil coolers from my trucks after loosing one transmission
  8. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,056
    Nov 18, 2014
    Land of local
    Lots of older trans don't have a cooler. Our old 13 doesn't. Usually runs in the 150 range
  9. Diesel Dave
    8,520
    23,433
    Jan 20, 2010
    Hesperia, Ca.
    I’ve been losing coolant(2 quarts a month or so) and I’ve been leaking transmission fluid when I’m parked. When I look closely where it left the small leak on the ground, you can see the orange/red coolant slightly with the trans fluid. So my thinking is that the transmission cooler is probably leaking coolant into the transmission. That explains my coolant lose and over flowing into the transmission which in return is cause the leak. So my question, Am I correct ? Im thinking of by passing the cooler and/or running the external ones without running the coolant like the older style. Im local and mostly hauled average to light loads. This is on my 2014 Pete Commiefornia truck.
  10. Magoo1968
    2,017
    5,395
    Mar 18, 2021
    St Malo mb
    Check condition of transmission oil coolant will mess it up over time .
    Diesel Dave Thanks this.
  11. Diesel Dave
    8,520
    23,433
    Jan 20, 2010
    Hesperia, Ca.
    I bypassed the trans cooler, drained and refilled with new fresh gear oil.
