I just noticed my hood is digging into the brass fittings of my oil cooler. I'm going to have a shop bypass it all together. Should I be worried about the transmission heating up without it? Right now my temp never really goes up much at all.
Transmission oil cooler bypass
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Skate-Board, Mar 24, 2015.
Page 1 of 5
Try replacing the rubber hood stop pads so the hood stays off of your cooler fittings.
Depends on how heavy you run and how much pulling you do in the mountains in the hot summer months.
Just bypass it if that's your intention and keep an eye on your temps. If all you do is 80,0000 5 axle work you'll be fine.Skate-Board Thanks this. -
bad idea to bypass cooler. its there for a reason. bypass temporarily to get home or shop to repair properly.
Your next thread title.
Guise, my tranny blew up, where to replace. -
Transmission cooler is an option.
Trans don't just blow up because of hot oil.
Lots trucks come from the factory with no cooler. It's an option.
If he has a lower hp rating and hauling light there not needed. -
My last truck was a 379 Cat 13 speed. Oil cooler started leaking coolant internally.
If I remember correctly I used one of the oil hoses and looped it back to itself because it had a pump and never had any problems. -
MJ1657 Thanks this.
Page 1 of 5
