Transmission Input shaft
Discussion in 'Trucks [ Eighteen Wheelers ]' started by kevlar, Feb 19, 2012.
  1. kevlar
    kevlar Bobtail Member
    7
    Feb 19, 2012
    Clanwilliam,MB
    Hi I'm new here and was needing some help. The transmission in my Kenworth came loose because of a few broken bolts. I removed the tranny and noticed the input shaft has some free play in it. Is this normal and how much if any?? Also wonder about the clutch, the tranny had about 1/4 inch gap at the top when I noticed it, and had run it like that for awhile, just thought the clutch needed adjusted. Will the clutch be ok? On the bright side atleast all the bolts didn't break! Would have made some noise then!!!:biggrin_2551:
  3. rrw811
    rrw811 Light Load Member
    82
    26
    Dec 14, 2011
    WI
    Hi there,from what I've seen input shafts do have quite a bit of play, the pilot bearing in the flywheel keeps the shaft tight and centered. As long as the pilot bearing still fits tight on the end of the shaft and the splines on the shaft aren't worn, it should be good to go. Imo the clutch should be fine, I've seen that happen more than once, clutch life usually isn't effected.
  4. Oscar the KW
    Oscar the KW Going Tarpless
    12,246
    28,114
    May 19, 2011
    Do not take a chance, replace the input shaft and the bearing it rides on. I had a bearing for the input shaft go out on my last truck, I wound up getting a new transmission, clutch and motor. When that bearing goes everything in the transmission drops down and it will lock up. Bent the crank so bad that they had to cut it so they could get the connecting rods off. It was ugly, cheap insurance to replace anytime you have to pull the transmission.
  5. rrw811
    82
    26
    Dec 14, 2011
    WI
    Wow I've never seen that happen! Maybe it is cheap insurance :biggrin_25524:
  6. Heavyd
    Heavyd Road Train Member
    7,749
    6,184
    Feb 4, 2009
    Well, since everything is apart, now is the time to replace it. Input shafts do have some play, like the others said the pilot bearing supports it. The problem now is that the shaft, clutch and pilot bearing have all been stressed by the trans to engine mis-alignment. Hard to say if anything is damaged, depends how long it ran like that. I would say to be better safe than sorry and just install a new input shaft, clutch and pilot bearing!
  7. KW Parts Guy
    KW Parts Guy Light Load Member
    230
    78
    Jul 16, 2011
    Get an Eaton k2468 install kit, runs about 200buck, input shaft, bearing, cross shafts bushings, fork, pilot bearing etc.
  8. Mr. Haney
    Mr. Haney Road Train Member
    2,693
    2,040
    Dec 17, 2008
    If the transmission was hanging on the clutch in anyway, the clutch drive discs will be bent in the hub area. This will cause disengagement problems
    Racer X 69 Thanks this.
  9. kevlar
    7
    Feb 19, 2012
    Clanwilliam,MB
    Thanks you guys! I suppose this isn't a good time to cheap out. Think I'll replace all those parts!
    Heavyd Thanks this.
  10. Oscar the KW
    12,246
    28,114
    May 19, 2011
    Spend a little now, save a whole lot later.:biggrin_255:
    Knowing what could happen now will give you a whole lot of peace of mind down the road.
  11. Racer X 69
    Racer X 69 Bobtail Member
    34
    11
    Mar 18, 2010
    In your rear view mirror.
    Mr. Haney is correct. The clutch disks could also be fractured from being run with the misalignment. If they are, they will eventually fail, likely it will be while the rig is rolling down the road, and that can get ugly. At the very least everything should be disassembled and inspected.
    If there was as much misalignment as you say there is also likely damage to the input shaft bearing, and that could explain excessive free play.
    One thing you don't mention is what kind of free play you have. Is it in and out, or side to side, and how much?
