transmission fluid check eaton fuller
Discussion in 'Ask An Owner Operator' started by bserious, Jul 15, 2014.
  1. bserious
    bserious Bobtail Member
    25
    Aug 10, 2012
    I have a 1998 fld 120 with a eaton fuller 10 speed, how do I check the fluid level on the trans?
    whiteliner70 Thanks this.
  3. spyder7723
    spyder7723 Road Train Member
    15,467
    25,009
    Mar 31, 2013
    sarasota, fl
    You've been trucking 12 years and don't know how to check fluid levels?!
  4. bserious
    25
    Aug 10, 2012
    Thanks for the input, i just wanted to see if there is a better way than the plug on the drivers side.
  5. wonderdog24
    wonderdog24 Medium Load Member
    377
    127
    Mar 1, 2012
    Puyallup,Wa
    Nope.... That is the only way
    bserious Thanks this.
  6. serozhah
    serozhah Light Load Member
    283
    45
    Sep 8, 2013
    how do you check the fluid level? with the truck off? How long should it be off before you check? Thanks
  7. Allow Me.
    10,642
    12,100
    May 28, 2009
    Rancho Mirage, Ca.
    you can check it engine on or off.
    serozhah Thanks this.
  8. serozhah
    283
    45
    Sep 8, 2013
    how do i replace transmission fluid? do i just unscrew the plug in the bottom to drain it? how do i refil the eaton transmission with new transmission fluid? Thanks
  9. double yellow
    5,946
    10,066
    Aug 28, 2011
    State of Jefferson
  10. LBZ
    LBZ Road Train Member
    1,771
    1,266
    Oct 22, 2008
    Road to Nowhere
    Why, there are plenty of good truck stop parking spots that need slicked up? :biggrin_25523:
    The other obvious thing when checking is making sure the truck is relatively level.
    Have seen some people checking engine oil with the truck on a pretty steep incline is the only reason I mentioned it.
    Deuce7500 and serozhah Thank this.
  11. serozhah
    283
    45
    Sep 8, 2013
    do you know whats more common in older trucks like from the 1999? synthetic or non-synthetic. I don't know what oil I got in there right now. Figured to play it safe and buy nonsynthetic to replace the fluid since it probably been running on non-synthetic. Thanks
    BoostedTeg Thanks this.
