TRANSMISSION FAULT ABS J1939 FAULT CODE 369 KENWORTH (2020) T680.
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Juanyi, Feb 1, 2022.
  1. Juanyi
    Juanyi Bobtail Member
    4
    TRANSMISSION FAULT
    KENWORTH (2020) T680 PACCAR
    What has been tried without success:
    • Turning it on and off six times then turning in the engine to clear the transmission fault.
    • Cycling through the gears 3 times then turning it on.
    Stuck at a pilot waiting for a tow truck that’ll be here at earliest two hours.
    Reason for edit: More information added.
  3. biopure22
    biopure22 Light Load Member
    87
    51
    Aug 22, 2021
    Truck type and year and engine type
    Juanyi Thanks this.
  4. Juanyi
    4
    Truck: Kenworth T680
    Engine: Paccar
  5. biopure22
    87
    51
    Aug 22, 2021
  6. Juanyi
    4
  7. biopure22
    87
    51
    Aug 22, 2021
    Gonna have to talk to dealer bro,unless pilot has Davie 4 software,which I dout..
    Juanyi Thanks this.
  8. Juanyi
    4
    Thank you very much, . Company is going to tow me out to get it done, I just thought it must be something I could do myself.
  9. biopure22
    87
    51
    Aug 22, 2021
    No problem,paccars are very hard to get info on ,good luck hope it’s not to bad,let me know how it comes out
  10. Ffx95
    Ffx95 Road Train Member
    1,368
    2,628
    May 18, 2017
    Let me know what you find out from the dealer I think I sometimes get this code when I hold manual mode for awhile.
    biopure22 Thanks this.
  11. Devtransport74
    Devtransport74 Bobtail Member
    Did you ever found out what was the problem?
