Transmission coolers
Discussion in 'Heavy Haul Trucking Forum' started by Oscar the KW, Aug 3, 2014.
  1. Oscar the KW
    Oscar the KW Going Tarpless
    12,246
    28,114
    May 19, 2011
    For the guys that are hauling heavy (+100,000) what are you using for a trans cooler, air or coolant?
  3. kat man
    kat man Light Load Member
    234
    195
    Nov 29, 2009
    orleans in
    Coolant on a 18sp.got water in trans caught it early on a rear seal seap.Replaced cooler then when warm weather hit I noticed trans running 30 to50 deg hotter replaced trans filter and its back to nornal.The air oil coolers are slow pulling temp back down,but no chance getting water in oil, I still donot have all the oil out of the radiator. The parts guys said they sell a few coolant coolers all the time.
  4. Pahrump
    Pahrump Medium Load Member
    coolant only way to go
  5. Pipe 40
    Pipe 40 Light Load Member
    209
    359
    Mar 24, 2012
    Toowoomba Queensland
    I've only seen air coolers here friend of mine put a 12v fan behind his with a switch on the dash. They seem to keep temperature down even when it's hot.
  6. leftlanetruckin
    leftlanetruckin Road Train Member
    3,607
    3,160
    Mar 12, 2009
    Mo Via Blackpool,Lancs.
    My air one went from 200 to 175 today, by turning the engine fan on. So they can lower temps quick enough with some thought.
    Never been a fan of the coolant type, for the reasons I said before.
    Hmmm, coolant and transmission bearings.....yummy.
    Martin
  7. Rontonio
    Rontonio Road Train Member
    6,251
    45,418
    Aug 9, 2009
    Mine is air.....because Martin is mostly always right and he recommended it. Temps come down fine but I almost always engage the fan manually when pulling a grade.
    leftlanetruckin Thanks this.
  8. dogcatcher
    dogcatcher Heavy Load Member
    808
    2,674
    Apr 30, 2010
    tn
    I have a coolant style, had a leak awhile back mixed oil and coolant made a mess of things. I do believe I bought the one I have now from Detroit radiator works its stainless steel core and they say its dam near bullet broof! so far it works no leaks and it keeps the trans temp way down
  9. HighCountry
    HighCountry Light Load Member
    172
    301
    Feb 27, 2014
    Stephenville, Texas
    Like the other bloke said, AIR, hands down.:biggrin_25523:
    Me and another driver spent summer pulling 240k up Cabbage Hill, all boxes always in the red.
    He ended up putting external cooler w/fan, worked excellent!!! I think he also plumbed it with shut off valves to run coolant thru for the winter. Lost track of him, not sure how that worked out. Good Luck. SteveB.
  10. Passin Thru
    Passin Thru Road Train Member
    1,918
    565
    Mar 8, 2007
    VA
    Ours is coolant in front of the radiator and coils for AC. Hooked in with radiator coolant, has Parker hoses look like they are off Cat Dozer. Runs whatever coolant temp is.
  11. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,727
    Jan 30, 2010
    keep stroking.
    I always remove the coolant coolers and replace with air coolers in front of radiator on all my trucks. works great. I don't use eatons air coolers I buy mine off a local hydraulic hose company that is twice as big and heavier duty in design.
