Transmission code MiD 130 PSID 232 FMI 9
Discussion in 'Volvo Forum' started by Baxy86, Jun 16, 2022.
  1. Baxy86
    Baxy86 Bobtail Member
    6
    Apr 21, 2022
    2012 volvo vnl 430 with ishift
    I was getting check transmission code
    almost every 1 hour, we replaced clutch, actuator, air compressor, transmission and transmission ECU, after transmission swap it worked fine for about 8k miles and bow it started doing same thing again, what else can i replace :(
  3. Another Canadian driver
    Another Canadian driver Road Train Member
    1,181
    4,263
    Nov 14, 2021
    ALBERTA
    I had that exact problem with my 2013. It ended up being my qualcomm wires. The two in question were the green and yellow, that i believe logs miles. One was grounded out. I spend 1200 at a dealer and they never found the problem. I found it when i had the fuse box lid on the dash off and was moving the wires around heard the a clicking noise and found one wire was a little worn and was grounding out. Hope this helps.
    SeawolfLarsen, May 6, 2018
  4. Baxy86
    6
    Apr 21, 2022
    I feel like it happens more when im going uphill
  5. Another Canadian driver
    1,181
    4,263
    Nov 14, 2021
    ALBERTA
    That poster that I copied the message from found that 1 wire shortening to the ground was messing up the whole communication.
    You should check all wires for possible grounding when moving.
    PIA? You bet.
  6. Baxy86
    6
    Apr 21, 2022
    Omg, when moving it will be fun
  7. Ahmadwhitehorse
    Ahmadwhitehorse Bobtail Member
    . Mid 130 psid 232 fmi 9
    Miss communication between engine & transmission. I had a horrible experience. Driving normal , all of sudden transmission stop spinning drive shaft ,so truck rolls until stop & engine shut off, turn the key off , turn it on back everything back to normal for a while!!
    Changed accelerate pedal with sensor, but no luck, replace the transmission tcu to test , & engine ecm , still no luck!!
    RIBBON HARNESS, inside the transmission!!! That was a problem!!
    If you see the harness ,you laugh.
    Tiny wire !!!
    Hope it helps.
