Transfer dump truck
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by Santinoshop1984, Jun 14, 2021.
  1. Santinoshop1984
    Santinoshop1984 Bobtail Member
    Texas
    Hello all I'm thinking of moving from California to Texas the cost of living over here is just ridiculous ,
    Would anyone recommend where I can start by looking anywhere in texas in the dirt business for my transfer dump truck and bottom dump truck
    Thanks
  3. mnmover
    mnmover Road Train Member
    1,237
    1,104
    Apr 5, 2009
    Lichfield MN
    I have never seen a transfer type dump truck in Texas, just semi hopper trailers and side dumps. Also end dump trailers.
    Santinoshop1984 Thanks this.
  4. Dino soar
    Dino soar Road Train Member
    4,789
    26,858
    Dec 8, 2017
    I'm not sure about transfer trucks but I'm pretty sure in Nevada they use bottom dumps.
    And if you're open to where you're moving to Arizona may use them also but I'm not sure about the transfer dump..
  5. Santinoshop1984
    Texas
    I hear Nevada does have alot of work for bottom hoppers I was just leading towards Texas
  6. Sumtinlidat
    Sumtinlidat Light Load Member
    120
    261
    Dec 17, 2017
    Las Vegas Nevada
    Transfers are still used here in Nevada. Belly dumps are used on almost every job here. We run double set ups at 129,900 gvw.
    baha and Santinoshop1984 Thank this.
  7. Ruthless
    Ruthless Road Train Member
    8,800
    86,173
    Aug 28, 2010
    The City.
    Whats the benefit of a belly dump vs a end dump? There is only one outfit that I've ever seen in my area that has any; and they do something different than about anybody; as their product is uncommon & they haul their own stuff so I expect the equipment has something to do with the unloading facility/
  8. Sumtinlidat
    120
    261
    Dec 17, 2017
    Las Vegas Nevada
    End dumps here are used more so for haul outs. Broken concrete and asphalt. Some base material for the smaller jobsites. Belly dumps can bring in 40-45 tons when pulled as trains into a site. Belly dumps here are used mostly to bring in a lot of dirt to lift a site. When there’s 10 or so trains on a job. They can move 300-400 tons per round.
  9. Ruthless
    8,800
    86,173
    Aug 28, 2010
    The City.
    Interesting. We don’t have trains out here. Different local states have different allowances on combos depending on axles and sometimes bridge law, depending on which state a truck is in, and sometimes what it is hauling/
  10. Cat sdp
    Cat sdp . .
    20,819
    71,604
    Apr 8, 2012
    Orion's Belt
    Operator error/ roll over is the biggest difference…you can get 40 tons of most material in a 36-37’ end dump….. maybe not legally.
    I don’t believe you’ll ever see them in the northeast. But what do I know, I don’t get out much
    Ruthless Thanks this.
  11. lester
    2,914
    7,842
    Jan 2, 2012
    NW, Iowa
    Belly dumps don't tip over, unless you are really talented
